Anyone do a JDM Engine swap on 92 SE?
Old Jun 20, 2005 | 04:27 PM
momaxima92's Avatar
Considering doing a JDM swap on my 92 SE - anyone done one of these and are there any "gotchas" involved?? I know the engines are from Japan and there may be some differences - just want to get some feedback before I dive in....
Mike
Old Jun 20, 2005 | 05:06 PM
«§»Craig B«§»'s Avatar
I believe the crank angle sensor is different, but other than that, it's pretty much the same
I hope you're not expecting any more power from it because they are still rated at the same 190HP as the US version.
Old Jun 20, 2005 | 05:07 PM
MrGone's Avatar
read the stickies
http://forums.maxima.org/showthread....85#post3124785
Old Jun 20, 2005 | 06:45 PM
shavedmax's Avatar
pick up a jdm FSM. just make sure you can read japanese
Old Jun 20, 2005 | 09:05 PM
Cliff Clavin's Avatar
Way out West
Mine has a JDM engine in it. Like MrGone said, read the stickies. Jeff and Keelan (spipedong90) are both very thorough with their information. Jeff did the work on mine and everything he did was top notch.
The cam position sensor, coil packs and some of the smog equipment are different. I also noticed that the IACV is a little different. I still have my JDM coil packs and they work fine, but Jeff swapped all of the other stuff I mentioned. In order to pass smog regs you will likely have to swap over your upper intake. If you have a 5-speed, you should do that anyway, to keep the power valve for the variable intake.
Another good idea is to replace everything that you can while the engine is out -- put in all new manifold studs, new seals, water pump and gaskets.
Old Jun 21, 2005 | 06:34 AM
momaxima92's Avatar
No smog regs in Alabama!!!
Old Jun 21, 2005 | 07:26 AM
Way out West
I don't have them, either, but if you have a 5-speed the variable intake is nice to keep with the car. Also, in the event you sell your car to someone that does have to go through DEQ, you might want to at least keep your smog equipment.
Old Jun 21, 2005 | 08:08 AM
beachballs4's Avatar
1990 Maxima ~ are the connecting rod bolts removable [how]/sold seperately? I've got a bad set on #5 rod due to being over torqued. The idiotic dealer who replaced the crank and bearings due to their mistake [as gone into in length prior] really screwed this up. That's the reason this rods bearing was making noise. They also stripped 4 pan bolts, left the chipped lower pully on it, 2 exhaust manifold bolts broken off, etc.... I hope I can replace these rod bolts in the car without having to remove the rear head to install a new rod.
Also: WHY can't I start new threads? I can't even search my posts to add on to the one I hijacked with this story.
Anyone know?
Old Jun 21, 2005 | 08:12 AM
"They also stripped 4 pan bolts" ~ actually they're broke off too, not stripped.
Stay away from Wilmington Nissan in Wilmington, NC!
derekinthez
Nov 13, 2022 04:00 PM
fastcarny
Oct 6, 2015 10:42 AM
I<3 A32's
Sep 10, 2015 11:07 AM
03VQMAX
Sep 5, 2015 03:47 PM
