Another AC Question
Old Jun 25, 2005 | 11:20 AM
djx82's Avatar
Another AC Question
Hi guys.. i finally replaced my burnt relay (RAD FAN 1) and i thought it would solve the problem turning the AC on, but it didn't turn on even with all the relays working.
1. The compressor turns on if i take a 12V tester and put in on the Pressure Switch(Either Wire)(2 Wires)
2. My Push Control Unit was resoldered but one wire(BLACK) from the (FRESH VENT CONTROL) is cut off. DOES THIS AFFECT THE AC from Turning ON?
3. What other devices should i check? Please help me out
(WIKING you might be kind of annoyed for repeating things over, but i tried my best so please again, help me thanks)
Old Jun 25, 2005 | 11:29 AM
Wiking's Avatar
Originally Posted by djx82
...1. The compressor turns on if i take a 12V tester and put in on the Pressure Switch(Either Wire)(2 Wires) ...
If bypassing =shorting the Pressure switch is the key to start A/C, the your liquid is low, -or- that switch is bad. Dont run compressor without knowing exactly; low liquid means low lubrication for compressor. Educate yourself with these videos, and you'll be wiser than me...
http://www.id-usa.com/how_to_ac.asp
http://www.id-usa.com/how_to_videos.asp)
http://www.cardomain.com/ride/748507/7
Old Jun 25, 2005 | 02:06 PM
djx82's Avatar
also... the shop put in a 134a refrigerant. I know that Maximas are R12. He ordered the 134a fittings.. but can this be the reason why my compressor is not turning on??
Old Jun 25, 2005 | 11:06 PM
Wiking's Avatar
also... the shop put in a 134a refrigerant. ...
..."but the shop": now u say its been in a shop for fillup. Shouldnt they have an warranty for their fillup [if no leaks]?
2. btw. fresh vent is not A/C related
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
