Fog lights not working ?
Been workin on the max all week: spec stage 2 clutch, fidanza, udp, ebay cai, ebay ftsb, kyb's and eibachs....... extremely happy with the results...however I got it all done and i noticed the fog lights were not working. I suppose they could have been out before i started the project...but they worked about a week ago. I checked the fuse (fog light fuse and all the other fuses under the dash)....checked the bulbs....everything seems fine. Any suggestions or can someone direct me to a thread?
also, the corner lights on the very end where the little minature bulb is under the yellow part is not lighting up either....is this related?
any input would be appreciated
Go over the areas where you have been working around this week and check for unpluged wiring harnesses,pinched wires,etc...On jobs as big as you have been doing it is easy to overlook things like pluging something back in....Good luck!
Originally Posted by Mattster
I cant get the foglight housings off so i cant replace the bulbs. WD40 didnt loosen the screws.
if so try taking them out with a easy out,or just drill out the whole screw and mabye replace it with a larger screw...
vingodine
45
May 21, 2016 12:46 PM
Viralkill
Aug 17, 2015 10:54 AM
98nismomax
Aug 13, 2015 12:44 PM
