keypad fix pictures
Old Jun 26, 2005 | 06:53 PM
xtrip's Avatar
keypad fix pictures
well here are some photos
these are the new ones.
twisted and soldering connections
i used heatshrink tubing to cover the solder
Old Jun 26, 2005 | 07:04 PM
xtrip's Avatar
reconnect the new keypad to the red and black wires.
more heat shrink for that connection
replacing the keypad with 2 screws securing pad to door
tuck the harness behind this clip
Old Jun 26, 2005 | 07:07 PM
xtrip's Avatar
here you can see how to replace the cables so they dont hit the window
door panel reattached!
finished
Old Jun 26, 2005 | 07:11 PM
xtrip's Avatar
refer to my earlier post if you missed it
http://forums.maxima.org/showthread....3&goto=newpost
Old Jun 26, 2005 | 07:21 PM
maxitech's Avatar
Good Job! That keypad problem plagues many cars!
Old Jun 26, 2005 | 09:50 PM
Wiking's Avatar
I've got lifetime warranty: keypad will never break in my max.
Glue your pics on free page at cardomain.com site for the needy.
Old Jun 27, 2005 | 07:53 AM
xtrip's Avatar
i updated the image links to a more permanent host.
i hosted them using the ip address at first because
the forum puts ***'s in my other hostname because it is stone.kicks-@$$.net
Old Jun 27, 2005 | 02:20 PM
3rdcharm's Avatar
why did u change? Where u hearing the clicking noise but no lock action? just wandering cuz thats what mines doses and all the threads say to resolder the door lock timer.
Old Jun 27, 2005 | 03:24 PM
generation3's Avatar
Thank you very much I've been needing to fix mine since water got in them. I'll do it this weekend after I put in my components.
Old Jun 27, 2005 | 04:21 PM
xtrip's Avatar
I changed them because the sytem was dead, no beeps or lights when pressed.
water had ruined the driverside pad. (due to cracks in the rubber)
I replaced both sides because i hacked up the passenger side to use on the driver door as a temp fix.
Mar 12, 2020 12:06 AM
thenewguyy
Sep 12, 2015 11:12 AM
doctorpullit
Sep 10, 2015 06:33 PM
markevans999
Sep 10, 2015 04:29 PM
videomano
Sep 8, 2015 03:28 PM
