Size of Axle Locknut
Old Jul 6, 2005 | 12:29 PM
vg92's Avatar
I'm going to replace the right-hand side half-shaft since the CV boot cracked during the winter. Does anyone know the size of the locknut? 34mm?
Also, when the half-shaft is removed from the tranny, will there be any fluid leaking out? Just want to get prepared before I start. Again, this is for the passenger side.
Old Jul 6, 2005 | 12:30 PM
Mizeree_X's Avatar
Getting back to his roots
I believe it is 36mm and I know Autozone will loan a socket for free.
Old Jul 6, 2005 | 12:35 PM
Jeff92se's Avatar
I'm needing a caw
Please review the stickies and the autozone online for reference.
Old Jul 6, 2005 | 01:36 PM
Pervis Anathema's Avatar
1 7/16" .
Old Jul 6, 2005 | 02:02 PM
«§»Craig B«§»'s Avatar
yes, you need to drain the tranny before pulling out either axle or else it will drain out of that hole
and it is 36mm
Old Jul 6, 2005 | 05:31 PM
Travis92se's Avatar
Good luck removing the axle bolt if you don't have an impact wrench. Just broke the end off of my breaker bar a couple of hours ago trying to break these things loose. What a PITA.
Old Jul 6, 2005 | 05:35 PM
vansskaterfreek's Avatar
id hope it is a snap on, craftsman, or husky, if not, why dont you have one of them brands?
Old Jul 6, 2005 | 06:13 PM
The axle nut can be easily removed with simple hand tools. However, you will need quality hand tools of the proper size, not the cheap crap you get from ACE Hardware and the like. Below is a Craftsman 3/4" drive 1 7/16" socket, a 3/4" drive slide bar, and a 3/4" drive 5" extension. I use part of an old lamp when I need more leverage. Have a partner push the brake pedal to the floor, apply pressure, and viola! One loose axle nut. It truly is that simple. Be sure to torque it back to spec once your repair is complete. To tight or to loose equals premature wheel bearing failure.
Old Jul 6, 2005 | 09:39 PM
garbury's Avatar
3/4" drive, whoa hoho. That ish looks beastly. Simple 1/2" is all I needed.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
