simple temperature gauge prob
need to know!! I have just recently been having some probs with my temperature gauge in the dash board console. when driving on a occasion the meter drops to zero or low, by itself. But if i tap the plastic it jumps right back to the appropriate temp. I guess this has happened due the bass from my system??!! lol What should i look for?
![clap](https://maxima.org/forums/images/smilies/clap.gif)
Originally Posted by 19904dsc
How difficult is it to replace the temp gauge? ..
Replacement is easy; Craigs page and/or manual. Check Favorite links at left:
http://www.cardomain.com/ride/748507/8
![](http://memimage.cardomain.net/member_images/4/web/748000-748999/748507_230_full.jpg)
where do you hook up the probes to because i have the same problem and when i hook up the probes to read resistance, i get OL. which means too much resistance but i m probably not putting them in the right place.
Originally Posted by domlcardio
oh nevermind i see it. so yeah thats what i did and i got OL so i guess its bad right?
i just replaced mine 5 minutes ago because the connector was so coroded the wiring just broke off. it would intermitently work if i went over a bump. its coverered in what's supposed to be a rubber weatherproof boot. with all the heat under the engine compartment it turned to plastic, allowed moisture in and voila. before you go and change the sensor check the connector
nah, itll only be trailered when it needs to be flatbedded to be worked on. im working on a 98 that i picked up to replace the 93. goldmember wont be touched until my garage is built. then i'll replace the entire floor with a 4th gen floor/rear suspension so i can lay out again. i have working under a tent, on top of dirt. for some reason it just doesnt feel proffesional.
doctorpullit
10-28-2019 10:58 PM
220k+ A32
18
09-22-2015 11:39 AM
RWCreative
09-21-2015 11:01 AM
