Rear end droning
Old Jul 13, 2005 | 09:19 AM
john93se's Avatar
Rear end droning
Hi all,
This is pretty confusing but I'll try to keep it concise. My SE has been making a droning noise that goes away when you make a sweeping right corner on highways; it gets more audible at higher speeds (not too bad at 35, very annoying at 65+) This problem has been the same no matter what tires are on it. I've just done rear rotors on it and I thought that one of them was locking up on it because it had locked up the first run and I heat treated the rotor (ouch). The passenger side rotor looks like it's barely getting used yet it is hotter after driving (so I'm thinking that they are all working now and none are locking up). I really don't think it's bearings (or if the rear end has bearings that would cause this kind of noise). I've been looking in the forum and I haven't really seen a thread that matches mine. If anyone has any idea as to what might be causing this noise please let me know.
Thanks,
John
Old Jul 13, 2005 | 09:29 AM
Wiking's Avatar
Originally Posted by john93se
... if the rear end has bearings that would cause this kind of noise....
Check out first if u still have bearRings...
Old Jul 13, 2005 | 10:17 AM
john93se's Avatar
bearRings? I'm confused, where would I find this bearRing? I'm not trying to be ignorant I'm just unsure of the location of those or if it's the same altogether.
Old Jul 13, 2005 | 10:27 AM
Wiking's Avatar
...it's bearings (or if the rear end has bearings that would cause this kind of noise)....
Dont take me too seriously.
Each wheel gotta have a functional bearing or u are in trouble, and its not ust noise. Jammed brakes have a possibility to fry the bearing.
login to autozone.com
...these are free:
Old Jul 13, 2005 | 11:59 AM
john93se's Avatar
I'm not finding any information on rear wheel bearings on autozone.com or partsamerica.com; I don't get any results at all...
Old Jul 13, 2005 | 04:33 PM
rawmax1's Avatar
You have to go to your friendly neighborhood stealership. It will be the whole Hub looks like about 109 per side.
Old Jul 13, 2005 | 11:45 PM
Wiking's Avatar
The bearing prices are from 5-10$; doubles up to 50$ ? Needs a extracting tool (or shop) to change.
Old Jul 14, 2005 | 04:15 AM
john93se's Avatar
stealership prices
Is there a way I can just get the bearing, I'm sure the stealership will want to see the whole hub. Thanks for the info
Old Jul 14, 2005 | 04:33 AM
Wiking's Avatar
1 Take bearing out from tha assy uself
1b Go to shop and let em do it (5$?)
2. Insert bearing into pocket
3. Hop to bear ingsHop, ask, show ol bearring
4. Swipe u Visa... (5-50$?)
5. Push new bearing into the assy
5b. Go to shop and let em do it (5$?)
Old Jul 14, 2005 | 06:05 AM
john93se's Avatar
I can only hope that they stock it in the parts department. The run around I usually get with them is rediculous. Well we suggest that you have it done here for 1,000 dollars because your car has some "other problems". Thanks for the advice, guess I was trying to make sure that they were allowed to sell just the bearing if that is the issue with the noise. Thanks again
Old Jul 14, 2005 | 06:11 AM
Wiking's Avatar
...just the bearing if that is the issue with the noise. Thanks again
Thatswhy I never will go to the stealership repairs...
Bearing noise is connected to bad roll: turning the hub/bearing should be easy and free. If any sideways play or sticking, replace.
Actually its the 'only' place which may make the noise except smtg scrathing to/in brake assy.
Old Jul 14, 2005 | 06:45 AM
915spd's Avatar
i have the same problem. i've been driving on it for like 2 years now. it's annoying, but it hasn't affected my driving any. i'd rather not pay the $109 per side just to have a little noise gone. just turn up the music.
Old Jul 14, 2005 | 06:53 AM
Wiking's Avatar
Thats what ppl tend to do, not to think whats life about, but turn volume, rock until the end.
When bearing is shot, u get a glimpse (maybe) of u stunt freewheeling rearwheel from mirror. Then dive into ditch.
Stop now an' think.
Whats left if that trigger point happens to be at 100mph?
Old Jul 14, 2005 | 08:01 AM
aksansai's Avatar
01 Maxima SE, 5-spd
Lest you forget that additional friction in your wheel hub assembly equals:
  • Poorer fuel economy.
  • Increased tire wear (due to erratic rotation).
  • More wear and tear.
  • Possible damage (from abrupt failure).
Old Jul 14, 2005 | 08:56 AM
john93se's Avatar
3 for me
I don't have the cash now, sometimes it's easier to pay for damage in incremental amounts until something really bad happens. Guess I can only hope the stunt would kill me so that I wouldn't have to pay for it all.. heh heh Yeah I guess I should go get it all checked out... The only reason I haven't was because I could turn the stereo up. But with the stock bose speakers and the volume increase of the bearing its hard to ignore... Thanks for the advice
Old Jul 14, 2005 | 09:24 AM
kcidmil's Avatar
Yeah... nothing like driving down the road and having a wheel lock up. Makes for a very interesting ride.
Wiking's Avatar
... I could turn the stereo up. ...
Keeping tires rollin is the basic. If too poor, pls walk. Too many innocent people are already killed by rockers ignorant attitude: my kids life does not matter a cent to 'em, they prefer to kill and get killed...
The wheel may clunk for years, or maybe YOU KILL smbdy -intentionally- tomorrow. Luckily we've got inspection that really keeps klunkers on junkyard where they belong to.
Old Jul 14, 2005 | 09:26 AM
Alex_V
How about just doing what wiking said and just get the bearing replaced? If you have to order the bearing no biggie, you'd be driving around on it any way. And if you cant do it yourself, just take it to a shop to press out old and press in new bearing. And your on the road again. Not to hard.
~Alex
Old Jul 14, 2005 | 09:40 AM
john93se's Avatar
I plan on replacing it shortly, going to look after work today if I don't leave too late. I just wasn't sure that the droning was a bearing to begin with. As a general rule I wouldn't be ignorant and drive with something defective to try to "-intentionally-" kill someone. And inspection has never said anything about my car being a klunker. After having two mechanics not see anything wrong with the noise I considered it closed until the volume increase just recently after replacing the rotors. But I do appreciate the information provided and I'll look into bearings tonight.
Old Jul 14, 2005 | 09:50 AM
Wiking's Avatar
I only know how lax inspection is in Colorado: actually ONLY engine emissions... I say terriblese.
Pls raise the wheel and grasp it. No free play, no noisy ro***ion: keep drivin. If noisy etc, it just may be a real danger.
Have a safe day!
Old Jul 14, 2005 | 11:14 AM
john93se's Avatar
Yeah I've done that to both and no noise, and that's why the mechs told me they couldn't understand what it is. I guess I could replace both of them for 200+/- a few bucks and then turn the music up.
Old Jul 14, 2005 | 11:25 AM
Wiking's Avatar
lol: the autoeditor did not like the word ro_ta_tion...
Well, if its checked, then no real risk.
Swap your rear wheels to front, just for a tst.
If the noise is continuous, it has to come from rotation. Cannot be but the bearing, and/or smtg brushing the wheel or brake (there should be a real scratch to be seen).
If the bearing seal is viewable (never opened max rear bearing), u may try to lightly to pry it open for adding some lithium grease spray.
Old Jul 14, 2005 | 07:26 PM
915spd's Avatar
Stop now an' think.
not to be a ****, but 100 mph? be realistic. how many times do you go 100 mph? what do you do, race riced out civics or something? i'm just saying this is my problem.
Old Jul 14, 2005 | 07:28 PM
915spd's Avatar
i still get 30 mpg. what's your point? sorry not to come off like an a-hole but my has 226,xxx on it already. it started a long time ago. if it's going to break, it's going to break. i'll just go out and buy another 3rd gen. they're everywhere.
Old Jul 15, 2005 | 12:50 AM
Wiking's Avatar
...be realistic. ..
Lost wheel rollin to u 40mph is a killer.
Wheels are connected to vehicle via the bearing: When connection is lost, wheel will not follow the vehicle any more. This seldom happens in P. And some ppl get killed like this yearly, death is realistic, happens only once and cannot be started over.
So pls think.
Old Jul 15, 2005 | 04:26 AM
john93se's Avatar
30mpg? damn my car is messed up then. I get 25 highwayish and 20-22 combined city. I've seen up to 27 but no more than that. 168k on my max
Old Jul 15, 2005 | 04:35 AM
Wiking's Avatar
Actually u cannot ever measure bad -or- good bearing-mpg with fill-a-tank wishyway...
Btw. Go get 'new' wheel hubs from junkyard.
Old Jul 15, 2005 | 10:54 AM
915spd's Avatar
So pls think.
you make a good point. but i'll wait.
Old Jul 15, 2005 | 10:55 AM
915spd's Avatar
keep up on the tune ups and oil changed?
Old Jul 15, 2005 | 11:37 AM
kcidmil's Avatar
Not if your car is lowered. My friend lost his wheel on his sentra while driving... that was cool
Old Jul 16, 2005 | 04:25 AM
Wiking's Avatar
LOL. If it had the level-5 rust recall not done, the wheel would be sittin in glovebox...
As u know, lost truck rearwheel nuts nad or wheels are missiles... My RV had real problem keeping the rear wheelpair nuts locked, one of the biggest pains.
Old Jul 18, 2005 | 08:43 AM
john93se's Avatar
Every 2500 miles. Maybe I need to do O2 again but before that when I had just replaced it I was still only getting 25 max. From what I understand that's pretty respectable. I've read about people on the forums getting like 18.
Old Jul 18, 2005 | 04:00 PM
kcidmil's Avatar
Just got back from my trip and I can say I am VERY HAPPY
26.5 MPG... w/ the AC on. Some of that was even doing 85-90 MPH on the interstate. About 3/4 of the trip was doing 70 MPH though, and all of it was with the AC... Driving around with the AC never looked so good on my pocketbook.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
BkGreen97
Apr 2, 2016 05:47 AM
AcuraLegend
Sep 22, 2015 04:22 PM
