so sick of my crappy gas mileage
Old Jul 18, 2005 | 10:24 AM
aw89maxSE's Avatar
02 sensor changed
spark plugs changed
changed oil
changed tranny fluid
will change the fuel filter soon
I mean, ! I go through gas like the air I breath. There has to be something I can do to help this problem or am I just going to be prone to having crappy mileage
Old Jul 18, 2005 | 10:28 AM
Mizeree_X's Avatar
Getting back to his roots
Originally Posted by aw89maxSE
02 sensor changed
spark plugs changed
changed oil
When is the last time you changed the fuel filter? Might want to Seafoam the intake manifold and get the injectors professionally cleaned as well. Also, how fast do you drive on the highway?
Old Jul 18, 2005 | 10:30 AM
Jeff92se's Avatar
I'm needing a caw
I bet those concrete 19s don't help. What is your mileage now???? What is your compression readings?? Maybe the coolant temp sensor is funky.
Old Jul 18, 2005 | 10:57 AM
Tarzan's Avatar
TODOs:
1. Repair the vacuum lines. Wiking's cardomain pages for info.
Old Jul 18, 2005 | 10:59 AM
garbury's Avatar
what about your distributor cap and rotor.
Old Jul 18, 2005 | 11:03 AM
Wiking's Avatar
2idees, both increase mpg:
- Install 2x4 under gas pedal
- start sittin in a civic
MPG doesnt really matter. Howabout 6$ per gallon?
Old Jul 18, 2005 | 11:04 AM
Wiking's Avatar
...hmm... and hoses or wires to pluggies?
Old Jul 18, 2005 | 11:27 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jul 18, 2005 | 11:43 AM
internetautomar's Avatar
mod or sell?
got a # on the mileage you're getting?
I get about 12mpg on my A/T VE doing about a 3 mile drive each way to work.
Old Jul 18, 2005 | 11:44 AM
Jeff92se's Avatar
I'm needing a caw
Open loop > You.
Old Jul 18, 2005 | 12:12 PM
mod or sell?
could be, except... I know that it goes into closed loop because when I had the knock sensor non-funct, you could easily tell when it switch modes. it was a dog in closed loop, but ran like a bat out of he|| in open loop.
nowadays it always runs good because the knock sensor has been dealt with
Old Jul 18, 2005 | 12:14 PM
Jeff92se's Avatar
I'm needing a caw
3 miles is barely enough time to warm up the coolant and get into closed loop. So even if it does actually make it into closed loop, you still drove 50-80% of the way there in open loop.
Old Jul 18, 2005 | 12:18 PM
mod or sell?
I actaully get up to operating temp in about 4 blocks right now.
in the winter is a whole nother story. I get to work first
Old Jul 18, 2005 | 12:20 PM
Jeff92se's Avatar
I'm needing a caw
That's pretty fast. Mine takes at least a mile or two for to reach operating temp. Middle of the temp dial
Old Jul 18, 2005 | 12:22 PM
mod or sell?
I'm a leadfoot in this car. so that probably helps
Old Jul 18, 2005 | 12:25 PM
Jeff92se's Avatar
I'm needing a caw
Yes, helps tear up the engine faster, that's for sure. I baby mine until it warms up. Then it's 7200 rpm time.
Old Jul 18, 2005 | 12:33 PM
Greeny's Avatar
¯\(°_o)/¯
And you wonder why spark plugs blow out? j/k.
Old Jul 18, 2005 | 12:37 PM
tripleGmax's Avatar
hey i know i remember reading a post about how youve never done a tune-up.....so logic says do that.....
Old Jul 18, 2005 | 12:43 PM
Cliff Clavin's Avatar
Way out West
I guess VE > VG in the mpg department, along with hp.
I routinely get 28-30 mpg on the highway (spirited driving, too) and about 25ish around town when I am running errands around Portland.
When I only go to work, my mileage isn't that great because my work is only 2 miles away. I usually coast most of the way there and the thing doesn't even get up to temp. Still, I will only put like $10 in every two weeks if I am only driving to work.
Old Jul 18, 2005 | 12:47 PM
MrGone's Avatar
thats only a 1/4 of the list I posted
Old Jul 18, 2005 | 12:48 PM
MrGone's Avatar
just wait until he complains about how much oil he burns
Old Jul 18, 2005 | 12:52 PM
tripleGmax's Avatar
VE = VG in mpg, cuz i get bout 28-30 highway and 20+ in town.
Old Jul 18, 2005 | 01:53 PM
aw89maxSE's Avatar
Fuel filter will be changed to and tripleGmax is right, I do need a tuneup most likely. Sorry guys, I don't have the exact miles per gallon, but give me a day or so and i'll let you guys know.
As of this, "What is your compression readings??" I don't know anything about that and the coolant engine temp sensor seems normal
Don't know much about this either other then I know what the distributer is, but not how it could affect my mileage, " what about your distributor cap and rotor."
" TODOs:
1. Repair the vacuum lines. Wiking's cardomain pages for info." You wanna explain why if I don't see anything wrong with them?
One more thing is that I am a delivery driver in it and I know that has something to do with it, but it still seems extremely bad. I drive between 65-69 on the highway
Old Jul 18, 2005 | 05:11 PM
mod or sell?
so? cars don't live forever.
not too mention they're cheap enough to replace.
my buddy normally has a max or 2 on the lot anyhow, so if I blow my motor and feel like swapping it, I'll just pull one from him.
Heck right now he has VG 5 spd sitting there with leather.
Old Jul 18, 2005 | 05:14 PM
MrGone's Avatar
When they are $300 I can see that, but when you have over $8000/$10000/$:eek4: into them I guess the perspective changes, not to mention when the number of times you've swapped engines is greater than number of cars most of the guys on here have ever owned.
Old Jul 18, 2005 | 05:26 PM
mod or sell?
true true.
that said my camaro for example does get babied, then again it's also older than most posters on this forum.
but that's already had it's motor swapped once.
actually the max has a quasi replacement on the horizon right now. just can't decide if I want to let the max go yet, or just have 3 cars at least until I get a legacy AWD Turbo'
Old Jul 18, 2005 | 06:05 PM
Jeff92se's Avatar
I'm needing a caw
Yes. But I also don't want to put up with an oiler that's down on compression for most of it's life. "Just swap"? Well a DECENT jdm ve is $700 and up. Just putting in another crappy engine that just happens to run is a waste. Especially for the huge pain and cost for doing it right.
I've done two swaps on my own and one for Chris. Even with the engine, it was still a few hundred dollars in spare parts to servive the engine right before putting it in.
Old Jul 18, 2005 | 07:10 PM
mod or sell?
who said JDM?
I check the motor in the car by him, so I know what I'm getting.
mileage is irrelevant to me, and if I can't drive like I stole it, I don't need it.
I only have 1 car to baby.
this swap is no more complex than any other, and is simpler than the one I've got going on in the gargage now.
Old Jul 18, 2005 | 07:13 PM
mod or sell?
BTW, I only paid $200 for this car anyhow. how much money you really think I'd put into it?
it is starting to rust in the door jamb so how much longer I'll keep it is questionable.
right now it's being kept because it's a 4 door.
Old Jul 18, 2005 | 07:31 PM
subs1000w's Avatar
this maybe a dumb question but if you dont know what your mpg is right now how do you know your getting bad gas milage
Old Jul 18, 2005 | 08:27 PM
Trevmister1610's Avatar
lol thats a good point, but im sure he is just saying hes gettin bad gas milage because he has to fill it up alot?
Old Jul 18, 2005 | 10:13 PM
Jeff92se's Avatar
I'm needing a caw
One should swap studs, do the ks, rear/front main seals, swap intake manifolds, do the waterpump etc... all parts and gaskets will cost a few hundred. That makes a bit more involved than a normal swap.
What swap are you doing now? Got pics?
who said JDM?
Old Jul 18, 2005 | 10:37 PM
Wiking's Avatar
...Don't know much about this either other ...
Too bad. Info is available; clic, read to learn and know, work to correct. After all is done, my max gives 22mpg city with A/C on, 30mpg higway 70mph. That when horses sweat...
Old Jul 18, 2005 | 10:51 PM
chrgdRapa's Avatar
stop changing the subject everyone, with today's gasprices this would be a good topic to take more seriously
think of it this way
get "E"mpty, drive to a gas station and fill it with ten dollars in hellevue's gas station that is 2.47 or so i beleive. Fill car with 10 dollars, reset the travel dist.
that will get you approx four (4) gallons which should get you about 80+ miles assuming you get city+highway. cars like cold air too (not the case these days but isnt a problem in washington), i also heard that bad air filters drasticaly impact gas mileage. yours looked fine though..
its kind of an illusion that it eats gas like crazy, i had that too because i put in about ten dollars per day. Do what ive told you, give me the number of miles you got before you reached Empty or below. then well figure **** out
Old Jul 18, 2005 | 10:56 PM
MrGone's Avatar
the way to measure mileage is to fill the tank up, drive, then record the miles and divide the number of miles by how many gallons it takes you to fill up the tank again.
Old Jul 18, 2005 | 10:58 PM
Wiking's Avatar
Originally Posted by chrgdRapa
...Fill car with 10 dollars, reset the travel dist....
That 'system' of yours error margin is 1-2 gallons. Not to mention that u will not get what the mob gauge shows... =guesswork.
Air Filter does NOT affect one bit of mpg. It juts chokes your horses.
Edit: And before u naysay against the filter issue, test it DIY. Put a plastic bag with small hole in front of u filter and drive five (5) tank fulls to calculate mpg...
Old Jul 18, 2005 | 11:03 PM
chrgdRapa's Avatar
the system is consistent so im sticking with it.
i also said that i heard the thing about the air filter, i didnt say its what i think. personally i think that bad mpg has to do something with his wheels because the engine's condition is good
Old Jul 18, 2005 | 11:10 PM
Wiking's Avatar
the system is consistent so im sticking with it....
I bet u do. And numbers keep fluctuating 20% because basics are false. Only after 5 tankfull u get, maybe, under 10% error level.
- your mileage has 5-10% error
- your fillup changes 1-2 gallons depending on tilt
- the filling stations are known to have 'tuned gauges': mob robs u
Alltogether, u never rEALLY know.
If u install peiseler -wheel, and electronics flow -gauge: THEN u just might...
But as u said. Keep what u got and enjoy...
Old Jul 18, 2005 | 11:41 PM
chrgdRapa's Avatar
if i had that much time and resources to calculate my mpg, then that would like, suck.
my numbers dont fluctuate that much, maybe by one or two miles but thats it. this is why i like the way i do things now. 4 out of 5 times i get gas at a same gas station.
Old Jul 19, 2005 | 12:04 AM
Wiking's Avatar
if i had that much time and resources ...
- in your case...and that is good. One driver, same habits, same person fillin up, similar flat routes with same load, tires allways checkEd etcetc...
i like the way i do
- in your case they give good info when tuneup is needed. BUT Absolute numbers: you may compare to others, but factually lol
- hlping THE same mobster (no... I am too harsh. There are also a couple of straight guys in this world...)
What I am saying, that mpg numbers always contain margin of error. And the error margin is not saying that the result are wrong. No. It tells that possibly the number is not right - nobody knows. Somebodys 25mpg might be actually more than else's 30mpg.
Hundreds of things affect mpg, every day is different; when 'rust recall 5' starts to affect, numbers drop terriblese. Your system (=also mine) will catch tHat. Still, for me 5-10% difference between fillups means business as usual: I am being robbed with 6$/gallon and mob and... unameit.
