window reg ques
Old Jul 28, 2005 | 06:26 AM
max723's Avatar
window reg ques
today myy front driver window died and fell into the door. does this happen everytime a window regulator dies. my back one is broken but the window didnt go into the door, it stayed up.
Old Jul 28, 2005 | 06:42 AM
Wiking's Avatar
Steel wires keep it up. When it goes haywire, obviously it drops down as hay has no such strenght.
Rear door: motor, elec wirings, dataline dead...
Click on: http://www.cardomain.com/ride/748507/13
Old Jul 28, 2005 | 08:57 AM
Kimuel's Avatar
When this happened to me, I used the broken wire, jammed it around a screw and tightened the screw. This held the window up until my Ebay regulator arrived.
Others have used duct tape...the most versatile item known to man.
Old Jul 28, 2005 | 09:11 AM
dtahsee's Avatar
I second the duct tape idea. Did that when my front passenger side regulator died a few years ago and am currently using tape on my rear driver side window as the regulator died a few days ago. I think Brain (internetautomart) has pretty good prices on the regulator. I will be getting in touch with him soon for my regulator.
Old Jul 28, 2005 | 09:22 AM
dtahsee's Avatar
When you say fell into the door, do you mean by force of gravity or it stays in the position it was in before it stopped working (Assuming the window was rolled down)?
Old Jul 28, 2005 | 05:46 PM
max723's Avatar
left is driver side, right is passenger side?
Old Jul 28, 2005 | 06:11 PM
Cliff Clavin's Avatar
Way out West
My driver door window dropped so hard, I am a bit surprised the glass didn't break.
My rear driver side one just slid down slowly (but woudn't move up). This happened when I was in between runs (drag racing) and I used some electrical tape to hold it up until I got a regulator.
These are common failures in our cars and I guess it just depends on how the wires get twisted and the plastic pulleys get broken.
Old Jul 28, 2005 | 08:58 PM
Josh's Avatar
just incase anybody needs it in an emergency situation i've had 3 windows held up for 2 yrs by securing the window assembly to wire that pulls it up and lets it down... hard to explain here are pics: http://web.ics.purdue.edu/~jtdubach/orgpics/reg1
http://web.ics.purdue.edu/~jtdubach/orgpics/reg2
all i did was secure it using some steel wire wound tightly around teh braided puller wire.
it was ment to be a temporary fix but turned into a permantent one since they havent let me down(no pun intended) yet.
Old Jul 29, 2005 | 04:47 AM
max723's Avatar
do you have any more info on exactly how you did this?
Old Jul 29, 2005 | 04:53 AM
disgruntled's Avatar
just take the door panel off, and right around the middle of the door will be a column(so that when pulled, the glass will come up evenly, which is the stock location for the regulator also), what he did was tied steel wires to the glass support right underneath the glass and then ran the wire all the way up, then just pull the wire up, then wrap the wire around the door handle when he need the windows to close. Also, to open, just unhook the wire, and let gravity do its thing.
Old Jul 29, 2005 | 05:02 AM
max723's Avatar
ok ill figure it out today, kind of ghetto but a lot cheaper than buying new regulators!
Old Jul 29, 2005 | 06:08 AM
Way out West
Don't be a cheap azz. Just fork over the $60 for a new regulator. I know most of you spend more than $60 on PS2 games and Taco Bell every month.
It takes about an hour tops to swap out and then you can actually roll your windows up and down.
Old Jul 29, 2005 | 07:12 AM
max723's Avatar
hey man if you got an extra 120 layin around feel free to buy me 2 regulators.
Old Jul 29, 2005 | 07:13 AM
internetautomar's Avatar
mod or sell?
just use some clear packing tape to hold the window up.
I drove around like that while I was doing my regs.
Old Jul 29, 2005 | 04:35 PM
Josh's Avatar
no no no...what the wire does is take the place of the plastic piece that broke off,it is so tightly wrapped that it holds its place on the cable that pulls the reg up and down. i dont "pull" or "let gravity do its thing" i press my window switch and it works just like normal.
mine way took that long and does exactly that, hehe.
Old Jul 29, 2005 | 07:43 PM
oh, got ya, I got that idea from the way your pictures looks, I guess I better look closer next time, but hey, both way would works, one being more of a craptacular fix i.e. mine.
Old Jul 29, 2005 | 08:08 PM
Josh's Avatar
those windows are fairly heavey and pulling it up by a steel wire would prob. mess up ur hand as well as the seals, but i see what your saying.
edit: w00t 200th post
Old Jul 31, 2005 | 08:22 AM
ghettoshark's Avatar
My regulator on all my windows already broke..... se and gxe. it really sucks, and i can't get my working gxe back since its a weekend and the garage shop isnt working.
Old Aug 1, 2005 | 10:56 PM
fspgtd's Avatar
I duct-taped WOOD under the broken window regulators on my '89 max GXE to hold the windows up... (hehe... good use of WOOD in an automobile!)
Old Aug 2, 2005 | 03:57 AM
mod or sell?
ghetto .
REDinLV
Aug 15, 2024 12:30 AM
Fbana41
Aug 29, 2016 12:18 PM
followthadollar
Sep 27, 2015 01:06 PM
