bleeding brakes/ss brake line install
Old Jul 29, 2005 | 06:03 PM
max723's Avatar
if you have abs do you need to bleed the abs actuator like the chilton says? also when installing speedbleeders do i just screw them in or use something like teflon tape or some other sealant?
Old Jul 29, 2005 | 06:06 PM
max723's Avatar
also is this the correct order? pass reaar, driver rear, pass front, driver front
Old Jul 29, 2005 | 06:32 PM
max723's Avatar
ttt ?
Old Jul 29, 2005 | 06:43 PM
adroga's Avatar
Where did you get the speedbleeders and how much were they?
The bleeding order sounds right, not sure of bleeding the abs actuator...
Old Jul 29, 2005 | 07:14 PM
Mizeree_X's Avatar
Getting back to his roots
I have ABS, just disconnect all 3 ABS wire harness connectors (as per the FSM) and bleed the brakes like you normally would. I think speedbleeders just screw in, when you loosen them the spring moves allowing fluid through a one-way valve or something. I'm guessing when you get them they'll have directions.
Old Jul 29, 2005 | 07:39 PM
adroga's Avatar
or you can unplug the battery instead of unplugging the abs connectors..
Old Jul 30, 2005 | 01:17 PM
max723's Avatar
ok unp;lug the battery, what order do you bleed them. is left driver right passenger?
Old Jul 30, 2005 | 03:28 PM
adroga's Avatar
yup.... right rear -> left rear -> right front -> left front
Old Jul 30, 2005 | 04:39 PM
Mizeree_X's Avatar
Not according to the FSM it isn't.
Old Jul 30, 2005 | 07:09 PM
max723's Avatar
what is it in the fsm, install the same as the 4th gen in the modification section writeup?
Old Jul 31, 2005 | 07:48 AM
adroga's Avatar
FSM: left rear -> right front -> righr rear -> left front ..
I guess thise would be the right way.. I have read in different place slightly different ways of bleeding... I am not sure why... sorry
Old Jul 31, 2005 | 07:52 AM
max723's Avatar
ok thanks. ill just do it this way
Old Jul 31, 2005 | 07:56 AM
mtnbikeair's Avatar
The way the speed bleeder works is it has a ball bearing inside of it, so when you loosen it the fluid wants to come out, but the ball bearing holds all the fluid in. Then you just go into your car and pump the brakes for awhile and the speed bleeders let all of the air out but no fluid will come out. Pretty simple stuff, and they cost about 8 dollars for two at autozone.
Old Jul 31, 2005 | 08:36 AM
Mizeree_X's Avatar
Its alright. Your first order is based on the fact that the general rule of bleeding brakes is to start from the wheel furthest from the master cylinder and then progress to the wheel closest to the MC. For some reason Nissan has its own bleeding order. Whether it really even matters or not, who knows.
Old Jul 31, 2005 | 08:47 AM
Pervis Anathema's Avatar
My '91 is non ABS. I flushed all the fluid two weeks ago in the order of lr, rr, rf, lf. Worked fine.
rbuswell
Nov 17, 2016 04:54 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
