ebrake light stays on
Old Jul 30, 2005 | 02:29 AM
aw89maxSE's Avatar
I put my ebrake down and the light stays on?
what's up guys?
Old Jul 30, 2005 | 02:52 AM
Wiking's Avatar
Originally Posted by aw89maxSE
...what's up guys?
...possibly eebrake.
- stomp it down
- Kill the lamp
- adj/replace eebrake sw = console off.
Old Jul 30, 2005 | 04:20 AM
Greeny's Avatar
¯\(°_o)/¯
You might want to check your brake fluid level.......probably low.
Old Jul 30, 2005 | 04:51 AM
erty67's Avatar
Decal Specialist
is it your "ebrake" light, or your "brake" light???? If your brake fluid is low, the brake light will come on. Now the more important question would be...why is it low???
Old Jul 30, 2005 | 05:30 AM
goon9's Avatar
Your check engine light is illumintaed is it?
Old Jul 30, 2005 | 05:54 AM
disgruntled's Avatar
Your fluid might be low, or there is a possibility of your e-brake switch is sticky/stuck.
Old Jul 30, 2005 | 07:45 AM
aw89maxSE's Avatar
I should know that it's most likely the fluid. I remember being low so I guess I check it out
Old Jul 30, 2005 | 09:08 AM
adroga's Avatar
If your braking feels mushly or weak then its the fluid.
I doubt that its the cable.
Old Jul 30, 2005 | 09:13 AM
dmontzsta's Avatar
Ford Only.
Definately check your fluid in the master cylinder. If it is full, then I will give you a warning that your alternator could be on its way out.
Old Jul 30, 2005 | 04:56 PM
aw89maxSE's Avatar
it was the fluid, problem fixed
now I knew that
Old Jul 31, 2005 | 11:08 AM
Wiking's Avatar
now I knew that
I eat my helmet if stock eeeebrake can affect tHat!
Old Jul 31, 2005 | 11:11 AM
max723's Avatar
what does the brake light have to do with the alternator going?
Old Jul 31, 2005 | 11:13 AM
tripleGmax's Avatar
what do you mean, when the brake light comes on its an indicator of low brake fluid. now go eat your helmet mang.
Old Jul 31, 2005 | 11:41 AM
max723's Avatar
it says that the alternator could be on its way out, why does teh light indicate this?
Old Aug 1, 2005 | 09:05 AM
Greeny's Avatar
¯\(°_o)/¯
On these cars the brake light and the charge light up when the alt. is about to go.
Old Aug 1, 2005 | 11:42 AM
customcracka's Avatar
Mine never did that.... I wish it did though
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
pktaske
Sep 4, 2015 08:40 AM
