Need help with temp gauge....
Old May 23, 2001 | 04:02 AM
Mr Super Baller
After my car has been running warm for about 10-15 mins the temp gauge shoots up to hot and stays there for about 5 mins, then it goes back down to normal for 5 mins, and back up to hot. This process keeps repeating itself the whole time I am driving. The radiator is full of coolant, the fans are working properly and the engine doesnt seem to be overheating. Does anybody know what can be wrong? The car also has 175,000 miles is there anything in particular I should look for? Thanks in advance.
Old May 23, 2001 | 12:21 PM
MaxPower13's Avatar
my guess is you need a new water pump
Old May 24, 2001 | 11:06 AM
C-Dawg's Avatar
Replace the water pump and you will be good to go, chief.
Old May 25, 2001 | 12:44 PM
BMaxin '91's Avatar
I'm having the same problem with my '91 SE. Is there any way to check the water pump? I just had my water pump changed @ 2 yrs ago.
Old May 25, 2001 | 05:05 PM
89GXE
Try banging on the dash (not real hard mind you)and
see if it will drop. This sounds exactly like my 89 and
I was able to cure it for a while by tightening the
screws on the back of the gauge.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
