i LOVE my vg (broken timing belt)...
and this is the reason im buying an 02 maxima for a third car.
yesterday while i was at work, my g/f calls me in my maxima saying that it wont start. it was running rough, she thought it needed gas, filled it up and then it wouldnt start. hmm...
time to go on a road test. i show up at the gas station, try and start it and it spins over real fast. yep, timing belt is broken. i call my svc advisor and get a tow truck coming. i go back to work, car shows up at the dealer about 30 minutes later.
so, another advisor who used to wrk at nissan tells me my valves are bent, because its an interference engine. i havent torn much into the VG, so i wasnt sure, i looked it up...
Valve Clearance | 0(0) |
yep... i was disheartened. everyone in the shop who knew nissans told me my valves were bent also... this car had been really good to me. i put monroe sensatracs on it, replaced axles for broken CV boots, and performed some maintenance when it was due... but never a major failure. its got 140000 on it, and i thought the previous owner had replaced it, i bought the car with about 120 on it IIRC.
so... time to tear into it. i get the upper cover off... there it is. but its tight. its not broken... wtf.
so i crank it over, it doesnt move. hmm. i get the lower off after fighting with the main pulley and theres the belt, with a section of missing teeth, right on the crank pulley. (the shop foreman called it too
so i get the belt off, and run a leakdown test, just to get a guesstimate on how many valves ill need.
cylinder 4, 0%
wtf...
cylinder 2, 0%
ummm, okay.
cylinder 6, 5%
i pull the tester out with air, to make sure its flowing properly... yep. tester is working and calibrated properly. a t this point, im happy. even if the rear bank is fuxed, its only one cylinder head to do a valve job on. so im happy.
and what do you know, the rear bank is all 5% or less. O M F G.
finish the timing belt, with new water pump and 3 new belts. $83.75 later and its alive again.
and all i can say is 'wow'. this car has been REALLY good to me. and thats why i wont sell it. ill always have a reliable beater.
yay
)so i get the belt off, and run a leakdown test, just to get a guesstimate on how many valves ill need.
cylinder 4, 0%
wtf...
cylinder 2, 0%
ummm, okay.
cylinder 6, 5%
yay
WOW you are lucky. With my luck if a T belt broke a least 1 cyl per bank would shoot a rod.
You might want to at least pull the rear valve cover and get a new seal or use some rtv on it. All 3 of max's are leaking, the 166K is only a little, the 187K would start to worry me and my parts car with 217K is leaking oil egnough for a steam of burn oil on the front and rear valve covers. I think all maxs have this problem its just not very noticeable untill after 200K. I already RTV'd the 187K max and thats the only one im keeping, so im good for a while. Nice save on your max
Now what about this 383 s10? Mine has the stupid 2.2L ><
~Alex
~Alex
~Alex
~Alex
but yeah... vortec 350 from a 99 suburban punched out, high compression and some other goodies. its 'in the works'.
u lucky S.O.B. good thing i did both my max's timing belts last month actually the motor from my '93 which went into my '89 i did it like last month and if i haven't changed it sooner the belt would have snapped cuz it had a massive amount of ugly crack on it. as for my new motor that went into my '93 the belt was fine but i didn't want to risk it so i just replaced the main gaskets from the top end of the motor along with the water pump, thermostat, and timing belt.
Originally Posted by BewstAdd1ct
yep, both are leaking, but not enough to worry me. its mostly cake, no burning or anything. i wonder if itll just seal itself up
that sucks... my 4.3 wasnt enough for me.
For V8 goodness in a s-10!!
Still got that 4.3 and computer you can sell me..
..this hamster wheel must die...(i do have a carbd 4.3 to put it, but its really old and mpg would suck) I do have a VG I could fab up to put in, it should be better then the 4.3 by a little and get 2x the gas milage lol.~Alex
bah, i do maintenance... i just thought it had been taken car of.
~Alex
i have the 4.3 PCM, i left the 4.3 behind, no one wanted to buy it and i moved and didnt wanna bring it with me. the harness im using to splice the 6.3L harness into the trucks body harness. but... i picked up the harness, pcm and engine (with a spun #4 and #8 bearing) for right around $350 shipped.
i dropped about $2700 on parts and machine work on the engine and assembled it myself. seriously, if youre gonna pull the 2.2. out, just toss a v8 in. the swap kit is like $160ish. ck out s10v8.com youll need a radiator and an e-fan too. you can get a 4.3l rad.
New Car
Hey guys I'm new to this whole Maxima thing! I've always been a straight Chevy guy and nothing but! My question is; I just bought a 89 SE and have no idea when the belt was changed last. I took a look at it and it looks fairly recent, but do I chance it? Or should I just change it.
And I would say that I'm fairly mechanicaly inclined ( as I have built 3 vehicles from ground up) Whats it gonna take to change the belt? I know I can do it, but is it worth the headache or is it something that I should just give to a shop and let them have their way with it?
Originally Posted by Red89maxima
...should just give to a shop and let them have their way with it?
I would say your were LUCKY.I bought my 93 max in Jan 94 (used w/11000 miles). At 68,000 I decided to chane timing belt, had a pretty good shady tree mech, change it out, total parts and labor (changed everything nissan said to change), about $300.00. TWO WEEKS LATER, the belt broke, $2,500.00 later all is well again.Today it has about 125,000 miles and I am wondering if I should change it again or leave . Any opionions??????
Randy
Randy
it's cheaper than a new motor or a new car
Well, had my belt done on friday & the guy told me it was the orginal belt on there!!! This car has done over 200,000 km's on 1 belt. He told me that it's teeth were so worn down, he couldn't tell which belt to replace it with. I know this belt hasn't been changed cause the dealership I bought it from never had a cam belt change on the records. You want to talk about luck, here you go! Plus, the water pump was still in very good nick & the other pulleys were good too! I love this car!!!!
Originally Posted by EdzMax
... he couldn't tell which belt to replace it with. ...
For me the weekend mech swap time was one work day, about 7 hours. But then, dont ask jeff...
it took me about 4 hours to retime the engine, replace the timing belt and water pump, run a leakdown test on all 6 cylinders, clean the spark plugs, replace 3 acc belts and set ignition timing, and fill and bleed cooling system.
this is my first timing belt on a V6, and my first time doing anything major to a VG engine, but i also am an ASE certified tech and have a slew of tools.
Originally Posted by maximapitko
lucky bastard
I guess I'm lucky after a AC nightmare on the Femme's last car , I now have a Mechanic for a b!tch!! Hello free labor on the goodies!!!
See that's how we cheat
whaaaat?
oh yeah, suggested labor time is 5.8 hours and thats if the engine is already timed, doesnt include w/p replacement or any engine tests...
its not cheating, its being gooood
Originally Posted by Wiking
That sentence is hollow. I would let smbdy else check what has been done and how. There are two possibilities for 3gen max belt types: round teeth for round teeth sprockets, squared belt on squared... There is no need to open the whole assy, just take out upper cover screws and any obstacles, bend it open and check. Also verify the tightness.
Maybe I put it this way: only one belt tooth type fits u engine.
Look carefully on the teeth, even stealership mechs cannot comprehend this higher order enigma... Yes, they provenly think any type fits any vehicle.
tsi6001
Oct 3, 2022 10:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
