very weird problem
Old Aug 14, 2005 | 10:12 AM
aarontrio's Avatar
very weird problem
ok. so i start the max and it seems to be missing and running rough but when i get to about 3500 rpms it kicks in and takes off like a bat outta hell....any answers??? i just replaced the plugs and feul filter about 50 miles ago.
aaron
Old Aug 14, 2005 | 10:18 AM
nismosleeper's Avatar
hmmm... Try vacuum leaks, and make sure that the exhaust system is working properly.
Old Aug 14, 2005 | 10:35 AM
aarontrio's Avatar
exhaust is new and i checked for vacuum leaks....my teacher at school says it may be an O2 sensor or a MAF sensor...
aaron
Old Aug 14, 2005 | 11:13 AM
Wiking's Avatar
Originally Posted by aarontrio
...O2 sensor or a MAF sensor...aaron
Unplug O2. Tst. If no behaviour change, its the ou-too... (is it?) Some say that O2 is not used on high rpm, but so far I havent found such info in FSM.
- U may also tst sensor resistance: 5.2-8.2 ohms @ 77°F (25°C)
- do ECU selftst
- Check light should be on. (dunno really)
http://www.cardomain.com/ride/748507/9
Old Aug 14, 2005 | 02:31 PM
internetautomar's Avatar
mod or sell?
VE or VG?
either one, I'd blame injectors. VE just gets to have the knock sensor tossed in for good measure.
Old Aug 15, 2005 | 08:32 AM
Alex_V
Ah the knock sensor, great for wasing power, money and gas!
~Alex
Old Aug 15, 2005 | 09:32 AM
pito11213's Avatar
Well I have similar problems on a potential max I want to get. The car needed to be jumped so I am guessing the alternator may be bad because when I went to start it it just clicked. Then when I jumped it it started but idled horribly. A terrible shake in the engine. Then when you put the car in drive it dies. TPS has already been changed and no check engine light when car is running. Possible causes????
Old Aug 15, 2005 | 09:39 AM
Greeny's Avatar
¯\(°_o)/¯
aaron
I would bet on it being the knock sensor and/or subharness...
Old Aug 15, 2005 | 09:40 AM
Wiking's Avatar
Originally Posted by pito11213
...Possible causes????
Depends on engine: VGE http://www.cardomain.com/ride/748507/9
Check charge voltage, alt leak current.
Old Aug 15, 2005 | 09:47 AM
pito11213's Avatar
Sorry... it is a regular VG. A 91 SE.
Symptoms:
Battery was dead and friend says it would not hold a charge (Alternator???)
Jumped battery for a few minutes then it starts right up (Alternator???)
Runs horrible. Terrible shaking and when I pressed the gas the rpms went to like 1500 and stayed there for too long. Put it in drive car shuts off. Starts right back up.
Old Aug 15, 2005 | 11:03 AM
Wiking's Avatar
...Terrible shaking ...
Batt and/or alt and/or wiring bad. ... problems like this, clic on:
http://www.cardomain.com/ride/748507/5
http://www.cardomain.com/ride/748507/23
Runs horrible: plugs, wires, cap, TPS etcetc. Seek out
http://www.cardomain.com/ride/748507/1
Old Aug 15, 2005 | 12:37 PM
pito11213's Avatar
You the man I will try the alternator.
AaronL
Nov 15, 2020 11:52 AM
05RLS2
Sep 27, 2015 09:24 PM
yamehoo
Sep 24, 2015 10:21 AM
bennuss
Sep 11, 2015 05:55 AM
