Problem with Wipers
Old Aug 15, 2005 | 03:54 PM
jigga123's Avatar
Problem with Wipers
I went to use my wipers today and they suddenly didnt work. When I got home I opened the top assembly and was thinking maybe it was the motor. However, when I opened it I can see and hear the motor spinning. The two wires are connected together by a cap that goes on top the first wiper and when I opened it they werent connected. I know this is hard to understand but if you;ve ever seen it you'll know what im talking about. Anyhow, I put the cap back on but it doesnt stay. What do you suggest? Is there any kind of adhesive or something I can put on it to make it stay?
Old Aug 15, 2005 | 03:58 PM
Mattster's Avatar
This happened to our Sentra awhile back. I cant remember exactly how we fixed it but We used a hammer or something hard and stuck the to rods together and hit them repeatedly till they seemed like they would say after lots of trials we finally got them to stay together. If they still wont say connected maybe try Liquid nail. Hope this helps.
wawa92gxe's Avatar
Just get a new wiper likage from dealer. About $15 ish.
Not too difficult to install but need a few try with strong fingers. You will know what i am talking about when you get to it.
good luck.
denga
Old Aug 15, 2005 | 04:19 PM
CyMax's Avatar
Dear God you actually beat them into submission!!! Excellent use of a BFH
Old Aug 15, 2005 | 05:21 PM
jigga123's Avatar
good luck.
denga
I wouldnt mind buying it but it looks like too much of a pain in da neck to change. I looked at it and didn't even know were to start, hammer is sounding pretty good about now. I was also tinking about JB Weld.
Old Aug 15, 2005 | 10:59 PM
Wiking's Avatar
Originally Posted by jigga123
...tinking about JB Weld.
Better change while weather is nice or youll be hammering in the storm by the highway. But then, many ppl like it tHat way...
Old Aug 16, 2005 | 12:40 AM
Red89maxima's Avatar
Changeing out the wiper trans isn' that hard of a job actually! They have plastic pivot sockets and they wear out. It's not uncommon, I sold alot of them when I worked at an autowreckers. Hammering them into place will work sometimes, but it all depands on how worn the sockets are. I'd just replace the whole setup if I were you. It's kinda tricky, but the hardest part is snaking it out of there and then popping the new sockets over the pivot ball.
Old Aug 16, 2005 | 06:49 AM
jigga123's Avatar
Well I bought the linkage $25 and Im gonna try to fix it first and if I can't Im gonna try to change it.
Old Aug 16, 2005 | 06:28 PM
maximapitko's Avatar
The Bulgarian Guy
you can alsways use rubber bands That solved the problem for me forever
Old Aug 16, 2005 | 07:20 PM
Rubber Bands???
I thought Hillbillies only drove old P.O.S's but thanks you have opened my eyes to a whole new lifestyle of the hillbilly
Old Aug 21, 2005 | 10:42 AM
tijkane's Avatar
Crazy glue is your friend! Mine popped out last year. You need to have the wiper in a caertain angle, put the glue on and than connect the cap back. You guyz are right you gonna need strong hand to give it a good pressure.
I did mine last Nov and it is still working.
Good luck!
Old Aug 24, 2005 | 09:13 PM
rafanthony's Avatar
I have the same problem, I spent two hours trying to get the side witht he motor on. I am in FL right now and the the car is useless without the wipers. Tomorrow is another day I guess!
Old Aug 24, 2005 | 11:43 PM
Wiking's Avatar
Another for about 6.000.000.000, new day for 100.000, doesnt arrive at all =dead end for 50.000 [average, human race, globally]...
The spot is stupidly tight in max. In stanza [bluebird] it has been cut open at factory, so no problem poppin that in. Maybe u can cut it also open?
One possibility I've used is that you obtain proper (crowbar -like) tool and have leverage from chassis on top of the arm joint 'cup' as it is placed on the motor joint.
Extar Lever arm - backing on chassis.
Old Aug 25, 2005 | 05:12 AM
GREGB287's Avatar
i just fixed this problem on my car the other day its simple. Open the top assembly. Look in the 2 sections where u can see the wiper linkage. what probably happened is the linkage came apart. for me all i had to do was snap them back together. i soldered the connection.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Noela
Sep 26, 2015 08:22 AM
