My VE(many pics - beware 56k)
Originally Posted by Joe Fontinyatz
Hhmm.. Those look very nice. About the same size as stock?
Originally Posted by MaxKlinger
I think those KC's are slightly bigger than stock, but in my opinion they fit the car very well. I think they're also available with a variety of different lenses and bulbs, so you can use them as fogs or driving lights instead of the super-awesome highbeam floodlights we put on. I think the 3rd Gen definetly has the advantage for adding mods like this because of its' clean, straight bodylines. There's no way to do something like this on my 4th gen.
Does this look about right to you guys after an hour of driving? Seems a bit under the center, but could just be the design of the gauge thats throwin me off.
Oh and BTW, that Toyota oil filter worked wonders so far. All I have to say is I havn't heard a clack since the first few minutes of the oil change. Thanks
Mine runs a little hotter than that. After bout an hour my needle is just above center
Temp gauge readings vary from gauge to gauge. When I swapped a VE cluster into my VG, the temp gauge read a good bit higher. Swapped the old one back in and it was back to normal. I don't think you guys can make an accurate decision on the shape of his t-stat just based off the factory gauge.
Well the car runs good, so I'll just ignore it. I do think my fuel economy could be a bit better, but I don't think it's cause Im running on the cold side. Or could it be? I think it's just a maintenance issue. Thanks anyway.
I think you were right Chris...
Originally Posted by Cliff Clavin
The SEs came standard with foglights, so it should be prewired, unless the previous owner did something drastic.
Maybe you can see something from up here, if they are actually still wired into the system.
Thanks in advance.
Hey Pervis,
You have a Toyota Previa too? I saw it in the background of one your pics above. That's what I have - a Max and Previa. I think they are both good cars to mod, koodos going mostly, of course, to the Max. Nice looking 3rd gen!
Btw, what spoiler is that. It looks hot!
Thanks.
-Mrkanda
Thanks.
-Mrkanda
Is it me, or did the the previous owner really decide to do something drastic to get rid of the fog lights? I tried to get as many meaningful in-depth pics as possible. Maybe you can see something, cause I really don't see where they could be mounted in those cut outs. Also, no wires near there at all.
Thanks in advance.
Thanks in advance.
Originally Posted by mrkanda
Hey Pervis,
Thanks.
-Mrkanda
Thanks.
-Mrkanda
Originally Posted by tripleGmax
well if there is no wire, then yes they probably removed them or moved them out of the way. if you cant find them, then maybe they are gone.
Originally Posted by mrgone
Nice looking car
Apr 16, 2020 05:15 AM
bigfrank
Oct 1, 2015 12:51 PM
