Engine rebuild
Old Aug 16, 2005 | 10:37 PM
Mattster's Avatar
Engine rebuild
Would It be worthly my time and money to get a engine rebuild kit or to find a VE Engine somewhere and put that in? Also If I were to get a VE engine would I also have to use the tranny for that engine or could I use my current tranny? About how much should I look at for a decent rebuild kit?
Old Aug 16, 2005 | 10:52 PM
CyMax's Avatar
Depending.
A. If you did the work yourself it might be cheaper to rebuild.
B. If not, just look for a J-spec and swap.
C. Tranny will swap just fine, ATX to ATX, MTX-MTX, no problem.
Old Aug 16, 2005 | 10:54 PM
Trevmister1610's Avatar
http://memimage.cardomain.net/member.../290861_88.jpg
that is a VE Correct?
Old Aug 16, 2005 | 10:57 PM
maximagxe90's Avatar
that a vg,
here is a ve engine
http://memimage.cardomain.net/member...778_2_full.jpg
you can't just swap a ve into a vg shell you have to do a lot of modification in order for the ve engine to fit into a vg shell,
the ve engine will not work with a vg trans,
you have to find a ve car that has a ve trans
i don't think it is worth it to do that swap,
Old Aug 17, 2005 | 06:19 AM
Matt93SE's Avatar
STFU n00b!
Originally Posted by maximagxe90
that a vg,
here is a ve engine
Please don't talk unless you know what you're talking about.
the VE and VG use the same tranny bolt patterns. if you hae a 5 spd, they will bolt right up. swap the carrier bearing as well though. it bolts to the back of the block under the rear engine mount. exchange those while the engine is off the car.
the hard part is going to be the wiring. everything else will plug right in. mounts line up, trannies bolt up, etc.
but doing the engine wiring isn't easy.
Old Aug 17, 2005 | 06:27 AM
matt,
he was talking about rebuilding his vg engine,
he asking if he should rebuild his vg engine or find a ve engine and swap that in also he ask if he should use the tranny that came with engine or use his current tranny,
James92SE
142
Jan 2, 2024 09:23 AM
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
maximusrising
Sep 2, 2015 09:55 AM
