Need help with Rack and Pinion R & R on my 90 Max
Old Aug 17, 2005 | 04:34 PM
Navorama's Avatar
Tomorrow, I am going to change out my Rack (looks like it will be the most difficult repair I have performed by my self to date). My repair book does not have a lot of detail on unbolting the U-joint on the steering column going into the rack. Can anyone describe what bolts/pins I need to remove. How difficult is it to install the new rack (gear/spline?) to the u-joint/steering column. Also, i'm not sure where I put the two different o-rings that came with my new rack. Does my 90 max have the spiiral cable mentioned in previous posts?
Thanx,
Nav
Old Aug 17, 2005 | 04:35 PM
subs1000w's Avatar
im pretty sure you just loosen the u jiont and it will slide out
the orings im guessing are for the hose conections
Old Aug 17, 2005 | 04:48 PM
Matt93SE's Avatar
STFU n00b!
your 90 will have some sort of spiral cable in it because of the horn and cruise buttons in the steering wheel.
just be sure the front wheels are straight before you pull the U joint off the rack, and make sure the steering wheel stays straight while you're doing all the work.
before you reconnect the U joint on the rack, be sure the rack is centered (as close as you can anyway) and the steering wheel is straight.
as for the U joint, it's usually a pain to pull off the rack. I used a couple screwdrivers, a hammer, and a cold chisel to spread the joint apart so I could remove the rack. you'll need to completely remove the bolt going through it, then pry the U joint open a little bit. that's about it. the rest of the job is pretty straightforward... but getting the bolts holding the rack to the firewall are a royal PITA.
I highly suggest removing the Y pipe to give yourself some room to work. makes the job about 1/3 the pain of trying to work around the pipe.
Old Aug 17, 2005 | 06:18 PM
maximutt's Avatar
I just got an estimate from the local shop to do mine, does $490 sound good?
Old Aug 17, 2005 | 07:56 PM
Matt93SE's Avatar
STFU n00b!
sounds pretty steep to me.
parts store steering racks are about $160, IIRC.. $330 in labor is pretty stiff unless it includes an alignment when you're done.
Old Sep 3, 2005 | 01:11 AM
red-line-racer's Avatar
damm 490 thats a rip off keep lookin around youll find cheaper
Old Sep 3, 2005 | 07:03 PM
internetautomar's Avatar
mod or sell?
costs all depend on where you llive.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
magiconthetire
Oct 26, 2015 09:03 PM
maxima297
Sep 30, 2015 03:32 PM
