RADIATOR FLUSH question
Old May 25, 2001 | 02:51 PM
mentor's Avatar
I got a tranny rebuild beginning of this year, but I havent had my radiator flushed. Sometimes the temp gauge goes crazy and heats up way tooo much...(even with aux tranny cooler installed)
Do I just need a simple radiator flush ? D-I-Y or dealer ? Whats the deal.... let me know what u guys think
Could it be something else... cause it happened some of the times.
Old May 25, 2001 | 09:15 PM
ray89se's Avatar
over heating
is both of ur fans running both of them
when was the last time u changed ur thermostat
do u have coolant in the radiator
Old May 26, 2001 | 09:47 AM
brubenstein's Avatar
The transmission cooler has nothing to do with the coolant temperature. Cooling sytems should have the coolant changed every two years. I think you should start with a flush, and make sure the fans come on when the engine gets hot. The temp guage needle should never go above 1/2 way with these cars.
Old May 26, 2001 | 11:14 AM
eric93SE's Avatar
Might not be a bad idea to replace the thermostate and/or the temp. sensor. You can clean the connections on the temperature sensor, I know alot of people have experience corrosion on the connector. When I did my water pump I went ahead and replaced the thermostate, I saw no performance difference but I know over time the termostate doesnt open at the right temp.
It's a pain in the butt to flush the radiator b/c there are two drain plugs in the block the one in the front will **** all over the alternator and the one is the rear is almost impossible to get at. I didnt remove the rear drain, so I just flushed with water several times knowing that in the end there would be a couple pints of water left in the rear engine gally. I used the better red antifreeze.
Old May 27, 2001 | 12:42 PM
Jaybird180's Avatar
I have searched for the plug on the engine block to no avail. Where is it? The photo in my Haynes doesn't help either.
Old May 27, 2001 | 08:21 PM
eric93SE's Avatar
Its above the alternator and on the engine block. It points a little downward. I think its a 14mm bolt. Sorry I couldnt give a better discription of its location, its been a while.
sctludwig
Sep 1, 2022 01:32 PM
Excalibur23
Oct 13, 2015 04:33 PM
RWCreative
Sep 21, 2015 11:01 AM
pears
Sep 18, 2015 05:25 AM
Violator
Sep 9, 2015 10:14 AM
