Daytime Running Lights
Old May 25, 2001 | 06:01 PM
Shep's Avatar
I've got one of the "Canadian" 93 SE's, and it's supposed to have daytime running lights I believe, it was mandatory after 90 or 91 (not quite sure). Mine doesn't have them though, and I've got no idea how to tell if there's a wiring problem, or if they somehow didn't put them on it. I've got the 93 brochure and it says "daytime running lights standard", so any feedback would be appreciated.
Old May 25, 2001 | 10:25 PM
hoey's Avatar
what lights go on when you do one click on the light switch?
it should just be the corner lamps that turn on
i guess those are your daytime running lights
two clicks would be your regular headlamps and fogs
Old May 25, 2001 | 11:52 PM
ninezero's Avatar
i have a canada max 90 gxe it has daytime lights.
Old May 26, 2001 | 09:34 AM
gslater
I have a Canadian 93SE.....
The daytime running lights are on as soon as you start the car. They are the highbeams run at a lower voltage. The only way they would be off is if you started your car with the parking brake on, as soon as you released the parking brake the lights would come on. I'm not sure why yours aren't on, but the above is the behaviour of them, hope it helps with your troubleshooting.
Old May 26, 2001 | 05:25 PM
hoey's Avatar
see i was wrong... so dont listen to me =)
tsi6001
Oct 3, 2022 10:23 PM
rtirbany
Sep 8, 2015 11:46 AM
Jeffesernia11
Aug 23, 2015 06:09 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
