Need help diagnosing problems
Old Sep 2, 2005 | 05:20 PM
jigga123's Avatar
I;ve noticed a few new problems with my Max:
1. WHen ever I go over a bump, even a small one the noise of the springs/ struts on the Rear passenger side is very loud. The struts are only a 1000 miles old. It sounds like the spring is strected too much.
2. After driving for a while I can smell anti freeze or something burning. However, the car doesnt overheat and the coolant level stays the same. The radiator is also full. Also, if I touch the engine its veryyy hott to the touch.
Old Sep 2, 2005 | 06:46 PM
red-line-racer's Avatar
i think ur first prob might be the exaust system it might be loose and making noise
Old Sep 2, 2005 | 07:00 PM
Greeny's Avatar
¯\(°_o)/¯
1. Have a helper push on the back bumper on the side you are hearing the noise while you are under it on that side preferably with a flashlight and looking at the suspension to see if anything is broken/bent,etc......
2.If its not leaking/loosing antifreeze, then its not antifreeze your smelling...A engine running at normal temperature will BURN THE CRAP OUT OF YOU!!!
Old Sep 2, 2005 | 07:08 PM
jigga123's Avatar
Tru, but better safe than sorry. I'll try those ideas about the suspension, thanx guys. COuld it be a control arm?
Old Sep 2, 2005 | 07:29 PM
Greeny's Avatar
¯\(°_o)/¯
Here is all the parts....
Old Sep 3, 2005 | 12:11 AM
Wiking's Avatar
Originally Posted by jigga123
...Rear passenger side is very loud. The struts ...
1. The struts assy big top 2" (?) nut which holds all bits inside the strut tube, unscrews by itself... If no locktite [or old nut] was used on the installation. Check, tighten as necessary.
2.a. Follow the liquid level; if it stays put, no problem.
2.b. We have engine producing 100kW output; 75kW is waste heat. (compare: one house heating needs 10kW)
Old Sep 3, 2005 | 12:14 AM
Wiking's Avatar
Here is all ...][/URL]
He needs rear pic...
Old Sep 3, 2005 | 08:13 AM
Greeny's Avatar
¯\(°_o)/¯
ooops!...Fixed..
Old Sep 3, 2005 | 10:46 AM
used parts's Avatar
If it's coolant you smell, maybe the heater core is going. You need to put a pressure tester on the system. Mabye the overflow bottle was full, and every cooldown the radiator fills back up...so coolant level isn't 100% accurate.
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Noela
Sep 26, 2015 08:22 AM
