hinge pins
Old Sep 2, 2005 | 06:47 PM
fred's Avatar
hinge pins
so i am finally trying to fix my door...and the question is: how do you get the pin out of the hinge? it appears to be spot welded to the hinge...also, where can i get these pins? stealership?
Old Sep 2, 2005 | 07:17 PM
Greeny's Avatar
¯\(°_o)/¯
Are you trying to take the door off?....If you are there are 2 bolts on each hinge that attach the hinge to the door.....
Old Sep 2, 2005 | 07:21 PM
Matt93SE's Avatar
STFU n00b!
you can't replace the pins. must replace the entire hinge. they aren't that expensive though. like $15 a piece I think.
Old Sep 2, 2005 | 07:58 PM
fred's Avatar
where to get? internetautomart? dealer? probably not a junk yard, as who knows how long before the pin goes bad on those too right?
Old Sep 2, 2005 | 08:41 PM
CyMax's Avatar
Yes IAM could most likely get them for you, but honestly you should be able to order these at any dealership.
Old Sep 2, 2005 | 09:24 PM
fred's Avatar
aight thanks
Old Sep 2, 2005 | 11:59 PM
Wiking's Avatar
aight thanks
loosen door bolts, raise door, install shims under (2thin coins?).
Old Sep 13, 2005 | 10:35 AM
Dillbag's Avatar
Suprise butsechs!!!
Yeah, super cheap at the dealership. You can only get hinges for the max.
AaronL
Nov 15, 2020 11:52 AM
cruce91
Sep 20, 2015 10:23 AM
nissan99
Sep 11, 2015 03:52 AM
beerman1378
Sep 8, 2015 02:19 PM
MikesChevelle
Aug 16, 2015 02:04 PM
