radiator resavoir
radiator resavoir
Hi guys does anybdy know how to fix a hole in the radiator resavoir bottle i cant seem to find one here in Puerto Rico,so if anyone knows how to plug it or cement it ill really appriciated. thank you, for any help, and by the way i need to change the engine valve cover gasket and a gasket next to the timing chain, can any body tell me were to find them becuase a full engine gasket set its running for 300.00 and im not working its to much for me right now, Thanks.
Originally Posted by maxima94ever
... how to fix a hole in the radiator resavoir bottle ...
- clean the bottle well. Cut some material off from it from places that really do not cause any structural weakness.
- If its a pinhole, use solder iron to heat the plastic around fluid, then drag over that place with a straight metal piece to create smooth surface. Use the extra material, heat it fluid to fill gaps.
- Long crack: Flat solder iron edge is best: if yout hole is long crack, first run it on both sides of the crack to create one higher 'ridge ' on top of the crack, then drag and level all this fluid mass down. Add plastic as necessary.
If no solder iron, gas flame can be used; problem is that lots light plastic ingredients burn and evaporate.
- U may use special plastic solder machine which has adding 'channel' in the nozzle. I have such device, and its great when the added materiel is excat with the being repaired. But seldom the case is that we dont know the materiel, and its age. In such case using the very same material is key to successful patch.
- use liquid sealant in the chain cover (some type may also be used on the bottle)
Unclejunebug
04-02-2016 05:42 AM
jchronis2552
09-23-2015 04:57 PM
RWCreative
09-21-2015 11:01 AM
