2 Questions
Old Sep 30, 2005 | 05:24 AM
str8max's Avatar
2 Questions
How in the crap do you get the rear deck speakers out of a 90 GXE?
I think I might have a bad altenator I replaced it about 2 months ago and everything seemed to be fine but in the last week when I get on it the battery light and brake light would come on...and now its just the reverse it stays on all the time and goes off when I get on it.
any suggestions?
Old Sep 30, 2005 | 05:33 AM
Krannick's Avatar
you have to remove the rear seat (vertical part)
and then to pull-up the deck (fastened in place with plastic clips)
you'll have access to the speaker then...
for the electrical trouble, my guess would be grounded wires...i've had this kind of troubles last winter, and i've found that i had about 7-8 wires that grounded partially with the frame of the car... (mine were located under the carpet, near the driver seat)
Old Sep 30, 2005 | 05:34 AM
Greeny's Avatar
¯\(°_o)/¯
any suggestions?
I'm pretty sure you got to take the back seat out to get the speakers out of a 90 max.....
Check the wiring on the alt...If it is ok then take it back to where you got it..You should have a warranty....
Old Sep 30, 2005 | 06:13 AM
bhunter's Avatar
I don't know about the speakers as I have all SE's, but check your alternator belt tension first. It may have come a little loose. It's not uncommon for new devices to go bad early either.
Old Sep 30, 2005 | 06:34 AM
str8max's Avatar
and the back seat comes out how?
Old Sep 30, 2005 | 06:54 AM
Cliff Clavin's Avatar
Way out West
Two 10mm bolts behind the armrest and two more 10mm bolts (one on each side) of the lower half of the rear cushion near the door. After that, there are several clips holding the seat down -- you have to yank the seat up out of them.
Old Sep 30, 2005 | 07:09 AM
Greeny's Avatar
¯\(°_o)/¯
Craig brace's site has good info on removing the seats and lots of other stuff too..
http://www.geocities.com/craigbrace/
click on the How to section.....
Old Sep 30, 2005 | 07:15 AM
str8max's Avatar
thanks................
Old Sep 30, 2005 | 10:10 AM
Phoenix's Avatar
Lives in a Maxima
the back seats are sooo easy to take out. After I get mine out, i felt embarassed that I had even asked.
Cliff's right though. No bolts holding down the bottom cushion, 4 bolts on the back cushion. You're probably going to want to take out that metal thingy too, but that's just 2 bolts.
Good luck on the speaker swap. What are you putting in?
Old Sep 30, 2005 | 01:40 PM
str8max's Avatar
well today I found out it was the altenator....so I will be replacing it again. dang reman. crap!!!!
thanks for the info on the seat......I am not gonna go all out considering this is my work car...something cheap just to replace the blown factory speakers
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
