ps2 in glovebox, power invertor, wiring help
Old Oct 2, 2005 | 05:25 PM
DMad8724's Avatar
I just put a ps2 in my glovebox (the new slim kind) and i was wondering how i should wire it up, im going to buy a power adapter that plugs into my cig lighter (but you wont see any of that) and was gonna unhook my cig lighter (the wires) from whatever it is hooked up to
the reason for this is because i wanna have it so the power invertor is on when the key is in the ON position (my 3rd gen has ACC, ON, and START), but I also want it to stay on while the car is being started (so it doesn't just shut off for a second) and was wondering if anyone knew how I should wire up my cig lighter for it to work like this
thanks!
Old Oct 2, 2005 | 05:59 PM
internetautomar's Avatar
mod or sell?
depending on the inverter you use, it may need to be reset every time you cycle the ignition. Mine was like that.
I'd check the power draw on the inverter when it isn't powering anything, and then relay the output side of the inverter.
Old Oct 2, 2005 | 07:08 PM
pest2001's Avatar
do you have any pics of the ps2 install? i was looking to do the same.
Old Oct 2, 2005 | 07:43 PM
disgruntled's Avatar
Are your power inverter going to survive engine crank? Thing is, when you crank your car, the voltage drops, which might causes the inverter to turn off, this negating your whole effort. I hope you did run a wire straight from the battery, and not off the wires that are already in the car, or you're asking for a world of hurt.
Old Oct 2, 2005 | 08:29 PM
CyMax's Avatar
Yep, I'm with him Isolate the circuit as much as you can, I would suggest useing the glovebox light + for a relay for the inverter. That way it is only receiving power when it is going to be used.
Old Oct 3, 2005 | 12:49 AM
Wiking's Avatar
Originally Posted by DMad8724
...so it doesn't just shut off for a second...
- if charge voltage & batt voltage already low, surely inverter will drop off during crank
- get that direct batt wire (fused), add relay to cut off when ign key off.
- install small (3Ah?) extra batt near u complicator for backup. Diode into the supply wire to block reverse flow durin crank. This in case dropoff still occurs.
Old Oct 3, 2005 | 01:03 AM
bradsm87's Avatar
Instead of using an inverter and going through the AC adaptor that comes with the PS2 which is VERY inefficient, you should make your own 12V DC - 8.5V DC converter and find a plug that will plug directly into the PS2 from that. That wouldn't use any more power than a factory standard CD player. That is by far the best way to go.
Old Oct 3, 2005 | 01:33 AM
Wiking's Avatar
Originally Posted by bradsm87
Instead of using an inverter ...
Idle current is about .5Amps, also efficiency does not really matter as there is ample amps to play with.
Another +++issue: Inverters total galvanic isolation from starter spikes ...
Otherwise, yes, leaner is mostly better.
Old Oct 3, 2005 | 01:49 AM
bradsm87's Avatar
It just seems silly to me going from 12V DC to 150V AC or whatever it is there in the US and back to 8.5V DC wen u can go straight from 12V DC to 8.5V DC
Old Oct 3, 2005 | 03:23 AM
Wiking's Avatar
It is. But what in the car -world isnt silly? Pay oil companies, state taxman, arabs 7$/gal for .05$ gas ...AND... 80% of its energy is wasted.
The Frye
Sep 2, 2021 11:03 AM
