Tried rebuilding the front calipers
Old Oct 4, 2005 | 12:18 PM
Tarzan's Avatar
The caliper repair kits that I bought from Carquest would not allow me to put in the piston. Twice I tried and both times the piston would simply slice off some rubber from the seals if enough force applied. The first time it happened I removed the ring that came with the kit and put the old one back in - the piston would go in with some effort. With the new ring there would be no way to insert the piston by hand. I tried a clamp and that's when it sliced the rubber. If compared with the old Nissan ring, the new rings are thicker. What was I doing wrong or was it a defective/wrong kit?
And yes, I did clean up the piston and caliper and did lubricate the ring and piston with brake fluid.
Old Oct 4, 2005 | 01:19 PM
Greeny's Avatar
¯\(°_o)/¯
I had the same experience with the rear caliper rebuild kit from idiotzone....Some of the rubber rings were the wrong size....
Old Oct 5, 2005 | 12:28 AM
Wiking's Avatar
Originally Posted by Tarzan
The caliper repair kits that I bought...
from --->Carquest would not ...
Oh boy. Typically here its suddendly the only vehicle, 20miles pedalin to city, rain...
Old Oct 5, 2005 | 07:26 PM
Greeny's Avatar
¯\(°_o)/¯
top reason why I buy my calipers already rebuilt.
they carry multi-million dollar insurance in case they f-it up.
if you rebuild it yourself and it is determined to be the cause of an accident, you are up ***** creek
I just took the kit back to idiotzone and got my $$ back....Then went to the local yard and pulled one off a low mileaged wreck....
wyobbagy
Jan 3, 2023 12:03 PM
BkGreen97
Apr 2, 2016 05:47 AM
6spd4dsc
Mar 4, 2016 05:19 PM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
