not sure If I had the compresssion stroke or not what would happen
Old Oct 6, 2005 | 04:45 PM
95turbo gxe's Avatar
ok I got this question I got the distributor to line up. But im not sure when I set the timing belt did I have it on compression stroke or not. If I did not have it on compression stoke and had it on exhaust stoke when I set the timing belt what would happen and how would it run
Old Oct 6, 2005 | 07:18 PM
Governor's Avatar
Best way to tell is by lining up the notches on the camshaft/crankshaft gears with notches on the rear timing belt cover then line up the white marks on the timing belt with them and you cant go wrong.
good luck
Old Oct 6, 2005 | 07:26 PM
DanNY's Avatar
Ad·min·is·tra·tor
check my response from your other thread
Old Oct 7, 2005 | 01:17 AM
MrGone's Avatar
how would it run
it wouldn't considering it would be 360* out
Old Oct 7, 2005 | 06:24 AM
internetautomar's Avatar
mod or sell?
if it's 360* out, he's in perfect time. :
Old Oct 7, 2005 | 02:47 PM
MrGone's Avatar
was thinking cams
DIAF
Old Oct 7, 2005 | 03:40 PM
mod or sell?
cams also rotate 360*
http://www.diaf.org/
Old Oct 7, 2005 | 03:44 PM
MrGone's Avatar
then i wasn't thinking at all
Eitherway it wont run
Old Oct 7, 2005 | 03:56 PM
mod or sell?
No comment
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
