Exhaust Leak on Y Pipe
Old Oct 11, 2005 | 01:39 PM
Tonyklem's Avatar
i have an exhaust leak on my y pipe. its about 3 inches in front of the flex section right on the top of it. the mounting bolts look pretty rusty, im affraid i might break the studs off or something if i try to get it off. are there any precautions i should take before trying to take the pipe off to weld it?
Tony
Old Oct 11, 2005 | 01:57 PM
bhunter's Avatar
If it is that bad get a warpspeed y-pipe and just replace it. If it is rusted through in one place what is the rest of it going to be like?
Old Oct 11, 2005 | 02:03 PM
Greeny's Avatar
¯\(°_o)/¯
A good muffler shop may be able to weld it on the car......
Old Oct 12, 2005 | 09:39 PM
mordezmoncou
if you take the y pipe out make sure to spray some bolt breaker spray on the bolts, and let it set for a few mins, also try to do it when the car is warm, not cold. the bolts come out easier this way.
My advise. Get a WSP y-pipe. call it a day.
But if you insist on welding the y pipe up, make sure thats not your only leak
max's are notorios for broken exaust manifold studs, wich can leak like heck and make you think your y pipe is leaking.
good luck
Old Oct 15, 2005 | 03:42 AM
maxgtr2000's Avatar
KH3 by popular demand
Best just let a muffler shop do it, or at least have them take the nuts/bolts, especially if there is any rust under there it is going to be a PAIN!!
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
A32goldylocks
Sep 16, 2015 01:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
