How do you hold the crank pulley still to loosten the bolt?
Old Oct 17, 2005 | 03:35 AM
bradsm87's Avatar
G'day,
I've gotta take my timing belt off to remove my heads to get them overhauled and I can't think of any way to hold the crankshaft pulley still while I'm undoing the bolt. If it was a manual, I'd just put it in gear with the handbrake on and that'd hold the crankshaft still but I have an auto so I can't do that. How have you guys done it?
bradsm87's Avatar
And how can I tell when it is at T.D.C of it's compression stroke?
Old Oct 17, 2005 | 04:12 AM
Greeny's Avatar
¯\(°_o)/¯
Take your inspection plate off,then use a big flathead screwdriver to stop the flexplate from turning by sticking it in the teeth of the flexplate and then bracing it against the bellhousing...
Or you can use a impact wrench if available.....
Old Oct 17, 2005 | 04:25 AM
Greeny's Avatar
¯\(°_o)/¯
Old Oct 17, 2005 | 04:26 AM
Wiking's Avatar
In cyl no.1:
- All valves about closed
- If this is so, and your luck persists, pressure happens
In VG distributor:
- rotor should be pointing to cyl no.1 -wire
Old Oct 17, 2005 | 07:39 AM
Harvs94max's Avatar
starter off screwdriver jam in flex plate
Old Oct 17, 2005 | 08:27 AM
Matt93SE's Avatar
STFU n00b!
impact wrench.
If you don't have one, take car to mechanic or lube place.
have them break it loose then put it on gently so you can drive home.
other option... stick breaker bar on bolt. turn engine until bar is just about to touch frame. get in car, tap starter. should knock bolt loose.
Old Oct 17, 2005 | 08:59 AM
garbury's Avatar
With my manual VE, I just had my dad step on the brakes while it was in gear. I don't know if it will work for auto, but try the brakes.
The engine is at TDC when all three punchmarks on the crank/cam gears line up with the punch marks on the block. You will know what I'm talking about when you look at the gears.
Old Oct 17, 2005 | 01:08 PM
Maxima Man's Avatar
Whats the best way to remove the pulley once the bolt is loose?
Normaly it is tough to get off right any tricks or tips?
Old Oct 17, 2005 | 01:28 PM
Greeny's Avatar
¯\(°_o)/¯
You need a rent a 3 jaw puller from idiotzone
Old Oct 17, 2005 | 01:44 PM
Maxima Man's Avatar
Is that the only way possible?.........
How much to rent?
Thanks MyGreenMax94
Old Oct 17, 2005 | 01:59 PM
Greeny's Avatar
¯\(°_o)/¯
How much to rent?
Thanks MyGreenMax94
That is the best and only way i know how to take it off...
They are like $20 to rent...But you get it all back when you bring it back...
Old Oct 17, 2005 | 02:25 PM
mrkanda's Avatar
Taking my Maxima to the Max!
I didn't know any better, so I wrapped a strap around the pulley with a wet strip of cotton cloth on the inside of the strap to build friction/ grip and then secured one end of the strap to a metal bar secured accross the top of the engine and other end of the strap had a buckle that the rest of the strap ran through and acted like a noose around the pulley. This alowed me to use a breaker bar to loosen the bolt because the pulley was held still by the strap as the strap tightened around it while I pulled with the breaker bar in the opposite direction. Also, the pulley came off using a three bolt puller (looks like a tree with a center shaft pushing against the crank shaft center). So --> "Necessity is the father of invention" -- what ever works.
Old Oct 17, 2005 | 02:37 PM
internetautomar's Avatar
mod or sell?
is that how you did it?
Old Oct 17, 2005 | 02:38 PM
Mizeree_X's Avatar
Getting back to his roots
The idiotzones around me didn't have 3-jaw pullers large enough for the crankshaft . I had to rent their crankshaft pulley puller instead, but it didn't come with the bolts for our thread type, so I had to visit a few hardware stores in order to buy some.
Old Oct 17, 2005 | 02:39 PM
mod or sell?
there has to be another way.
mine was pulled in the street with normal hand tools
ask kyle (harv94max) he did mine
Old Oct 17, 2005 | 02:54 PM
Greeny's Avatar
¯\(°_o)/¯
I sure there is another way,i just don't know of one that would not damage the c/p.....
When i changed my crank seal i didn't even need a puller...I just gave it a good yank and came right off..
Old Oct 17, 2005 | 05:04 PM
Governor's Avatar
Put a rag around pulley and hold it tight with a chain wrench...lossen the bolt but keep it on..put two pry bars behind pulley then tap on the bolt while prying from the back..and yes you will need a third hand..a tiny one..this will work I promise...good luck
Old Oct 17, 2005 | 05:21 PM
bradsm87's Avatar
Do you need to drain the tranny fluid to take the inspection plate off? I can't seem to find it. I have a VG. Is that diagram from a VE?
Old Oct 17, 2005 | 05:22 PM
bradsm87's Avatar
And what the hell do you use to hold the cam sprockets still while you undo the bolt???
Old Oct 17, 2005 | 06:12 PM
Greeny's Avatar
¯\(°_o)/¯
No need to drain the fluid....The insection plate is between the tranny bellhousing and the engine,just on the bottom....
Here is a pic of it off the car....
You got to remove the bottom tranny bolts[5 i think] to get it off of there...
Old Oct 17, 2005 | 06:52 PM
Governor's Avatar
chain wrench holds the crankshaft pulley while you turn the bolt...you didn't ask how to get the camshaft sprockets off.
Old Oct 17, 2005 | 07:45 PM
maxitech's Avatar
I was under my car today and noticed the crank pulley has a chip on the edge and has started to separtate at the seam a little bit in one spot. Anyone ever heard of a crank pulley failing?
Old Oct 17, 2005 | 10:09 PM
Matt93SE's Avatar
STFU n00b!
only times I've seen one fail is from severe abuse at a junkyard.
that rubber cracking a bit shouldn't cause any major problems unless the thing completely starts falling apart.
for the part of it that's chipped, just be careful and make sure the belt running next to it isn't fraying or anything..
As for how to hold the crank sprockets still, I use a rubber strap wrench. (a rag and a chain strap wrench mentioned above works fine too).
also, try popping the bolts loose on the crank sprockets BEFORE removing the timing belt.. often that works due to the engine's compression. make sure everything is at TDC before you actually remove the belt, bolts, and cam sprockets.
Old Oct 17, 2005 | 10:23 PM
CyMax's Avatar
+ Impact wrench = < 1 hr job
Old Oct 17, 2005 | 11:29 PM
Wiking's Avatar
How much to rent?
Thanks MyGreenMax94
No to rent. Time to think your own tools: some steel, holes bolts - an all drops off from u command. Zero dollars. Well, no visual t hing to bo ast...
Old Oct 18, 2005 | 05:24 PM
vizslak7's Avatar
Go spend $30 for an impact wrench capable of 220 lb/ft (you do need a compressor though) and it is very easy.
Old Oct 18, 2005 | 05:48 PM
Greeny's Avatar
¯\(°_o)/¯
Naw...You don't need a air compressor..
Old Oct 18, 2005 | 06:41 PM
bradsm87's Avatar
I successfully pulled everything apart ready to take the heads off (I won't take em off till Monday because that's when the reconditioning company can fit them in).
I gave up on undoing the crank pulley and I have the timing beltdangling out of the lower timing belt cover which I will take off when I get home.
My question is, can i put the timing belt back on without taking the crank pulley off because the belt is allready in the 'gap' and the pulley itself has a T.D.C. mark which faces up onto the lower timing belt cover.
Old Oct 20, 2005 | 02:12 AM
Wiking's Avatar
...pulley itself has a T.D.C. mark which faces up onto the lower timing belt cover.
If u have not rotated engine w/o belt, marks do align. Cranck engine with a wrench few turns before starting.
litch
123
Jan 4, 2024 07:01 PM
TKHanson
Nov 24, 2018 01:39 AM
RealityCheck
Oct 2, 2015 06:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
