PCV location (1993).
Old Oct 18, 2005 | 11:02 AM
chrisZ's Avatar
Hi,
Where is the PCV (valve) located on the engine? I bought a replacement and wish to install it (for the first time at 130K km), but can't find the darn thing.
Chris...
Old Oct 18, 2005 | 11:03 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by chrisZ
Hi,
Chris...
VE or VG?............
Old Oct 18, 2005 | 11:06 AM
chrisZ's Avatar
I'm sorry, not quite sure, but the engine is the slow one (two valves per cylinder).
Old Oct 18, 2005 | 11:12 AM
Greeny's Avatar
¯\(°_o)/¯
You got a vg motor...
it's gray/silver in color.
looking from the front..it's upper right of the intake manifold (where it says 3000 SHOC) or something like that. there's a hose connected to it. you have to basically disconnect the hose and unscrew the PCV valve out. if you know where the coolant bleeder screw/bolt is..it's right next to it.
Old Oct 18, 2005 | 11:13 AM
Wiking's Avatar
...but the engine is the slow one (two valves per cylinder).
Valve qty does not define that. Power comes from gas & some pressurized air explosions. That qty defines pwr. So get more air in, ECU injects more gas, get more pwr out.
PCV? Pwr How? Check the link.
Old Oct 18, 2005 | 11:21 AM
chrisZ's Avatar
Sorry, it was just my attempt at humour, valves = power.
Anyhow, thanks for the location of pcv info. I kept looking for a black one as the one I purchased is black?!
Thanks again!
Old Oct 18, 2005 | 12:38 PM
GRNMAXDMON's Avatar
just look for a black hose that comes out from the top of the rear valve cover and into the intake plenum and u'll c it. once u find it just unscrew it out and install new one and put the hose back on it with clamp.
Old Oct 18, 2005 | 03:31 PM
tripleGmax's Avatar
i sent you a pm ChrisZ
Old Oct 18, 2005 | 03:57 PM
ghostmax's Avatar
If the PCV valve on the VE were that easy to get to, I would've replaced it long ago. Wished it were in the same place as on the VG.
Old Oct 19, 2005 | 02:11 AM
Wiking's Avatar
Originally Posted by ghostmax
If the PCV valve ...
Drop hose end down, block intake side. Models 1910-1980 its like that. The whole in-vent-ion came to be mid 80's as greenpee catalyst$ started milking car owners = unnecessary de vice. Its drippin, so make it do not on exhaust.
Old Oct 19, 2005 | 06:42 AM
Tarzan's Avatar
Cleaning the PCV valve with injector cleaner achieves exact same effect as replacing - frees up its movement - enough for it to work perfect.
Old Oct 20, 2005 | 07:36 AM
GRNMAXDMON's Avatar
u can do that but i like it when i put new parts on my motor better. i know my car feels good about it too.
Old Nov 6, 2005 | 07:53 PM
Duckman540i's Avatar
VE Powah!!!
Could one of you show a picture of the location of the PCV Valve on a VE. Also what would be the steps to cleaning it?
Thanks Alot.
Old Nov 6, 2005 | 08:19 PM
internetautomar's Avatar
mod or sell?
it's on the back of the upper intake manifold and it screws in
Old Nov 7, 2005 | 07:00 AM
Greeny's Avatar
¯\(°_o)/¯
Thanks Alot.
You can use carb cleaner to clean it....Click to enlarge
Old Nov 7, 2005 | 07:30 AM
Tarzan's Avatar
That's VE motor, dude, the asker has VG.
VG: stand at the driver fendor side and look at the intake plenum. The back of the intake plenum closer to you is connected to the red valve cover with a thick rubber hose shaped as S. The hose attaches to the plenum with the PCV valve.
Old Nov 7, 2005 | 07:40 AM
Greeny's Avatar
¯\(°_o)/¯
You need to read the post i quoted...dude..
Old Nov 7, 2005 | 03:07 PM
CyMax's Avatar
Sweet!! Thanks for the pic!!
Old Nov 9, 2005 | 05:27 PM
VE Powah!!!
So that small valve on the backside of the engine is it? Just spray carb cleaner on it & wipe with a rag? Thanks MyGreenMax94.
Old Nov 9, 2005 | 05:36 PM
Greeny's Avatar
¯\(°_o)/¯
To clean it you need to take it off and spray inside of it...But really though,as cheap as that part is and the trouble it will take to get it off..I would just replace it with a new one...
Old Nov 9, 2005 | 06:36 PM
mod or sell?
yup, it's a $5 part
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
fx4five
Oct 1, 2015 04:58 AM
