short throw shifter
Old Oct 25, 2005 | 10:15 AM
Brad's Avatar
short throw shifter
were is the cheapest short shifter i can get for my new 93 SE. PS 89 SE for sale doesnt run due to screwed up fuel injection system. symptom is getting way too much fuel to engine, dealership doesnt know exactly what the prob is but pretty sure entire system needs to be replaced. pics available via email
Old Oct 25, 2005 | 10:25 AM
Cliff Clavin's Avatar
Way out West
Pacesetter STS is the cheapest one at about $75 +shipping new. Maybe if you shop around you can get a better deal.
Pacesetter on ebay
Old Oct 25, 2005 | 10:48 AM
Harvs94max's Avatar
or get a 4th gen b&m off ebay for around $80 shipped
here is the link for the 4th gen write up
http://forums.maxima.org/showthread....&highlight=sts
Old Oct 25, 2005 | 07:30 PM
todamax's Avatar
Dont buy the Pacesetter, its a chunk of ****. I installed one with my 5-speed swap, and less than a year later I replaced it with a 5-gen B&M. You have to mod the thing it bolts to, but it is very straight forward. The B&M is about 90% better than the pacesetter. Still a bit notchy, but doesn't expand and make it almost impossible to shift when hot. I hated the Pacesetter.
Old Oct 26, 2005 | 06:07 PM
internetautomar's Avatar
mod or sell?
on this note, quickie question
how do I make my shifting easier?
just pop in some redline?
Old Oct 26, 2005 | 06:16 PM
Greeny's Avatar
¯\(°_o)/¯
Push the clutch in...
Old Oct 26, 2005 | 07:06 PM
mod or sell?
:doh: maybe I'll get the hang of these fundangled manual thingamabobbers.
Body work tomorrow?
Old Oct 27, 2005 | 05:23 AM
GRNMAXDMON's Avatar
does the 5th gen B&M STS fit in my VG? or is it the same for the VE?
Old Oct 27, 2005 | 07:55 AM
Way out West
all 3rd gen shifters are the same.
You have to modify a newer one, but it can be done. Check the link in Harvs post a few up.
Old Oct 27, 2005 | 11:39 AM
twinkle's Avatar
I have never had ANY problems with my pacesetter, and i regularly take it on 2 hr trips, and after getting off the highway, it still shifts fine, Granted I didn't super tourque the nuts holding it together, but It does work well, at least in my car.
Old Oct 27, 2005 | 08:15 PM
todamax's Avatar
Mine were not tight. When cold, the thing was loose (think hot dog down a hallway). When hot... well, tight is tight.
Old Oct 27, 2005 | 10:03 PM
MyBlue92Maxima's Avatar
whats the differance between putting a STS in a car and just cutting down the stock shifter?
Old Oct 28, 2005 | 03:05 AM
Greeny's Avatar
¯\(°_o)/¯
Short throw shifters have a higher fulcrum point[longer on the bottom],so it takes less movment of the stick to get it in the next gear...
Cutting the shifter down looks better IMO,but doesn't change the fulcrum point of the shifter...
Excuse the crude drawing...
Old Oct 30, 2005 | 11:44 AM
JDM-M5's Avatar
So excuse me for sounding ignorant but I have just recently bought a 92 VE and this is high priority on my list for mods right off the bat. So does the 4th or 5th B&M STS work better and which is the easier to mod for fitment?
Thx
Old Oct 30, 2005 | 08:14 PM
todamax's Avatar
Thx
B&M works better, but install is custom. Pacesetter is crappy but easiest to install.
Old Oct 30, 2005 | 09:23 PM
JDM-M5's Avatar
Ok that's cool but the question still stands as I understand about the Pacesetter issues........Some people in this thread seemed to have modded the 5th gen to work as well as the 4th. Is this true and if so which of the B&M 4th or 5th gen would be easiest?
Old Oct 31, 2005 | 06:53 PM
JDM-M5's Avatar
Thanks for all the info guys.........
Old Nov 6, 2005 | 03:17 PM
Duckman540i's Avatar
VE Powah!!!
If you cut the stock shifter, it will still shorten the throw a bit. Also how bad is the Pacesetter from experience? I may be getting one used for a real good price. How bad is the notchiness, is it really hard to go through the gears? Some feel like an on/off switch, going through the gears. Like there's no inbetween, just clicks hard into the next gear.
Thanks.
Old Nov 9, 2005 | 05:33 PM
VE Powah!!!
Bump....Anyone??? I want to make sure it will work OK before I buy it. Thanks.
Old Nov 9, 2005 | 05:44 PM
Greeny's Avatar
¯\(°_o)/¯
If your really picky about smooth shifting then i would say don't buy it..They are notchy, but it's not that bad...I don't have any problem with it myself...
Old Nov 9, 2005 | 07:03 PM
subs1000w's Avatar
i had the same problem with the pace setter getting alot tighter when hot but i took it apart again and put washers to space it out and its much better now
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
maxinout93
Oct 31, 2015 02:04 AM
atriuum
Sep 28, 2015 01:19 PM
