Gas Smell Is Gone....... BUT.....
Old Oct 25, 2005 | 05:36 PM
Alon26's Avatar
Finally got around to looking into that STRONG gas smell inside my car. Turns out, some idiot drilled 4 holes into the tank, from a previously mounted amp or ground wires. Also the smaller of the 2 hoses was split open.
Anyway I got the tank and the hose changed, When to the gas station, got about $14 in and it stopped taking the gas, That was only about 1/4 tank. So I forced some more in and it came back out. I mean it poured out.
Anyone knows whats going on here?
I later tried to put some more in from a 5 gallon bottle, It took some, then flowed over, then when down very slow. I still haven't gotten it to 1/2 tank as yet.
Any Ideas???
Old Oct 25, 2005 | 05:38 PM
Alon26's Avatar
Thanks in advance...
Old Oct 25, 2005 | 05:42 PM
Greeny's Avatar
¯\(°_o)/¯
There is something in the filler neck obstructing the flow of gas into the tank.......Strange ...
Old Oct 25, 2005 | 06:11 PM
tripleGmax's Avatar
or your gauge is way off and its actually full....?
Old Oct 25, 2005 | 06:13 PM
Greeny's Avatar
¯\(°_o)/¯
Hmmm...Thats a thought...
Old Oct 25, 2005 | 07:50 PM
Alon26's Avatar
No, the tank was definatly empty, I got it from a junk yard. I put in a few gallons to get it started, then I went to the gas station. $15.00 93 octane doesn't fill us up these days. So It has to be something else.
Old Oct 25, 2005 | 09:03 PM
Krannick's Avatar
if i remember correctly, you have a kind of "breather" hose that is on top of the tank and ends up near the gaz cover....maybe it is "clogged" and since air does'nt move freely in it, the pressure from the gaz going down builds and "tells" the gun that it is full
Old Oct 26, 2005 | 04:50 AM
Hectic's Avatar
sounds like you're driving the first US car bomb. i'd use a toilet screw plunger thing, stick it in the filler, grind up whatever's blocking it.
Old Oct 26, 2005 | 07:32 AM
Wiking's Avatar
Originally Posted by Alon26
...Any Ideas???
Any ideas w/o any hlp:
- why did u change? Just use the screws with a rubber piece securing against leak.
- u have found the income for rest of u life. Just keep sellin...
- squirrels nest inside, you are about to be arrested. Bury em silently...
- it was truck gas station fast fillup pistol?
- u really got tank full with 14$
- the installed tank was for Trabie
Old Oct 26, 2005 | 02:12 PM
shuka6978's Avatar
maybe your gauge isn't working correctly
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
