VG Air Box Question !!
Old Oct 28, 2005 | 05:17 PM
Maxima Man's Avatar
My 1989, VG, se max's air box has a screw whole on the back side of it, and the screw hole faces up it is for a 10 mm screw. It is molded to the top half of the air box housing.
What in the world is it for ?!?!
Should it have a 10 mm screw in it or shold there be nothing in the screw whole?
Thanks in Advanced !!
Old Oct 28, 2005 | 05:44 PM
Greeny's Avatar
¯\(°_o)/¯
Old Oct 28, 2005 | 05:48 PM
Maxima Man's Avatar
Thanks for the info myGreen max !!!!!
i DONT HAVE A PIC TO POST
Old Oct 28, 2005 | 11:49 PM
Wiking's Avatar
Originally Posted by Maxima Man
...air box has a screw whole...
1. Top/Bottom part???
2. Hole is through or airflow blocked???
All air has to go through filter. As said, W/O pics, not possible to know wassup, ... tape/screw/block it and listen. If u gain hp, then its
your turbo screw that has drpped.
I need 12pcs 20-30mm bolts to block the holes... But I will not choke my hungry horses.
see details at http://www.cardomain.com/ride/748507/2
Old Oct 29, 2005 | 06:18 AM
Greeny's Avatar
¯\(°_o)/¯
Is it #1 or #2??? Not sure if this airbox is the same as yours,this is a ve airbox...
Old Oct 29, 2005 | 10:21 AM
tripleGmax's Avatar
hmmm a screw hole with no screw.
i would imagine youre missing a screw my friend.
Old Oct 30, 2005 | 12:13 PM
95turbo gxe's Avatar
maybe its a sign of some sort?
Old Oct 30, 2005 | 01:30 PM
goon9's Avatar
...ditch the box?
Old Oct 30, 2005 | 02:53 PM
kcidmil's Avatar
Drain?????
Old Oct 30, 2005 | 07:04 PM
Dillbag's Avatar
Suprise butsechs!!!
It's just a spot for a clip on the MAF wiring harness to secure to. They break off and are missing on alot of cars. (spot 2)
Old Oct 30, 2005 | 11:05 PM
Wiking's Avatar
Originally Posted by kcidmil
Drain?????
Medics install injector here for the horses?
Old Oct 31, 2005 | 12:51 PM
Maxima Man's Avatar
It is spot # 1 I am talking about but it looks a liitle different on a vg air box.
Wiking I know you have a pic of your airbox looking straight down with it installed in the car
If you post that pic you would see the screw hole!
Anyone know what it is for?
Thanks.............
Old Oct 31, 2005 | 01:32 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks.............
It's been a while since i have had the factory airbox on there,but i'm pretty sure it is mounting screw for the resonator box....
Old Oct 31, 2005 | 06:05 PM
Maxima Man's Avatar
Should it have the screw in place since it sucks in air after the filter?
I think it should
Wiking post one of your great pics!
Old Oct 31, 2005 | 06:16 PM
Greeny's Avatar
¯\(°_o)/¯
Yes.....Yes....Yes....Ummm...Yes......This is not rocket science dude...Just put a screw in it....
Old Oct 31, 2005 | 09:48 PM
tripleGmax's Avatar
for real .
Old Nov 1, 2005 | 12:59 AM
Wiking's Avatar
...Wiking post one of your great pics!
Dont know ? which one of the 400 on CDomain or the 3Gb at PC...
This one ? cannot be what u want... as said, just plug the hole, no harm done.
Old Nov 1, 2005 | 12:36 PM
Maxima Man's Avatar
Ok I got a screw for the hole
All is well now !
The screw hole in that pic is between the air surge tank and the air box top half.
Thanks for the help!
Old Nov 1, 2005 | 10:11 PM
Wiking's Avatar
Ok I got a screw for the hole ...
There should be a plastic clip support for MAF wire. Mine is broken half.
matts95max
Apr 23, 2025 10:44 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
