Manifold Stud Question - Y-pipe
Old Nov 1, 2005 | 07:55 AM
yandianj's Avatar
Did any of you guys have to remove the y-pipe from the cat when you relpaced the exhaust manifold studs or is there enough room to work by just unbolting it from the manifolds?
Thanks!
Old Nov 1, 2005 | 08:12 AM
Matt93SE's Avatar
STFU n00b!
yes, you have to remove it fromt he cat. otherwise you'll have no room to get yourself under the car as well.
this isn't a 10 minute job.....
Old Nov 1, 2005 | 10:15 AM
Tarzan's Avatar
I know this job is still doable even with a welded exhaust system. The guy, who did my studs, did not have to unbolt the cat (though I do have a flanged cat now).
Old Nov 1, 2005 | 12:53 PM
yandianj's Avatar
Appreicate the response. I have set aside 2 days for this one. Just need to get another gasket now.
Old Nov 1, 2005 | 01:40 PM
goon9's Avatar
...is it possible to 'just unbolt the manifolds'
It took me a weekend.
Old Nov 1, 2005 | 02:09 PM
yandianj's Avatar
I'm expecting it to be at least a 2 day job. It sounds like the rear manifold came off completely. Not to mention the exhaust stink the vents suck into the car now.
Old Nov 1, 2005 | 06:23 PM
goon9's Avatar
If you have your gasket, all the hardware, right angle drill, drill bits, EZ outs. 2 FULL days is realistic, I didn't have a choice and i got it done in that time.
Old Nov 1, 2005 | 06:33 PM
Matt93SE's Avatar
STFU n00b!
last time I did the job, it took me 6 hours start to finish, and I had to drill out 6 studs between both heads.
Old Nov 2, 2005 | 08:57 PM
DcHeath's Avatar
takes time for sure
Old Nov 2, 2005 | 11:27 PM
mattcomet82's Avatar
wow, you guys are quick. i had 6 studs to drill out between 2 heads, and it took me about 5-6 days. and i even had a lift! my damn job got in the way though....
lrb6805
Sep 17, 2015 04:49 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Violator
Sep 9, 2015 10:14 AM
