headlight help pleeeeeeeeease
Old Nov 2, 2005 | 11:32 AM
ElVito1981's Avatar
I need a pair of E36 BMW headlights that are already mounted on the OEM brackets. I originally bought the headlights and did the work to make the brackets E-36 ready, but I messed up and as a result the right corner light won't fit snug into the right bracket and is loose. I don't wanna have to do all that work again.
I just put up a thread explaining this on the For Sale/Parts Wanted section, but since I need this ASAP so that I can pass inspection and drive my car, it doesn't look like I'll find what I'm looking for anytime soon. So I might have to just reinstall my OEM headlights. However, since to do the E36 mod I had to clip the electrical wires, I'll need to buy 2 OEM headlight adapters/harnesses. Anybody know where I can get them? Thanks
Old Nov 2, 2005 | 03:36 PM
xx-Marshall-xx's Avatar
kthxbye2u
well dang...its not an easy operation? i actually want to do this mod to my car...but idk im not a car fanatic ...well i love em, but i dont get into them in depth and stuff... i wish i did but ANYWAYS! i want those E-36 lights they deff look nice on the maxima, and on top of that there HID halos
this isnt my thread but anyone have indtructions? i saw them on here before i deff forgot where i found it sorry
Old Nov 2, 2005 | 06:29 PM
disgruntled's Avatar
can't you just solder the original wires back on? or did you cut them so close to the connectors that you can't anymore? In that case, bust out your multimeter, and find out which is ground, which is the higher wattage wire, and which is the lower one, then you can just solder them straight into the headlight for the time being until you can fix your problem.
Old Nov 2, 2005 | 06:38 PM
tripleGmax's Avatar
ah geez.
ok test fit the corner light connected to teh bracket without the headlight in there. if you can line it up alright them great. put the headlight in. might have to take out the grille to do this but it will work. they are easy to bend (well the way i cut them) so line them up without the headlight in.
as far as putting the stock headlight back in the adaptor is easily found at walmart/autozone/anywhere
good luck sir
Old Nov 3, 2005 | 07:15 AM
ElVito1981's Avatar
k sounds good, I'm gonna try that. in case the brackets are messed up (I think they are) where can I buy new OEM headlight brackets (just the brackets without the actual lights)?
Old Nov 3, 2005 | 08:29 AM
Tarzan's Avatar
Solder and cars just do not go well together, not in cold climate anyway.
Old Nov 3, 2005 | 06:56 PM
wolfpack_5150's Avatar
Apple Pie Monster
care to enlighten me/us why solder doesnt work well?
Old Nov 3, 2005 | 07:16 PM
I think he is referring to the contraction/expansion of things when there are sudden climate changes (freezing weather, then got hot within minutes (engine bay)), thus causing the solder joints to weaken and eventually break off. It is not unfounded (ahem, our oh so reliable clock and digi gauge cluster), but when you solder two pieces of wires together, I think there is a minimal chance of that happening, plus the fact that you can actually heat the wires up much hotter, thus making a proper soldered joint, unlike the cold joint done through speedy & cheap manufacturing process that are prone to failure.
Old Nov 3, 2005 | 07:51 PM
ElVito1981's Avatar
i'm gonna buy E36 headlights again. Anybody know if the TYC E36 Euro headlights or the E36 rally style (black housing) headlights could be modded to fit my 3rd gen? Cause I'd rather not get the regular E36s again; they're kinda plain compared to the other two.
Old Nov 3, 2005 | 07:56 PM
tripleGmax's Avatar
you could probably mod any e-36 headlights and get them to fit. if i could do it again, id get projectors....mmmm projectors.
Old Nov 3, 2005 | 08:07 PM
ElVito1981's Avatar
yeah but do you know for sure if the rally style projectors will fit?
Old Nov 3, 2005 | 08:09 PM
tripleGmax's Avatar
post a picture for me
Old Nov 3, 2005 | 09:25 PM
ElVito1981's Avatar
http://cgi.ebay.com/ebaymotors/92-98...ayphotohosting
Old Nov 4, 2005 | 02:13 AM
ColombianMax's Avatar
mmm projectors...mmmm 79 bucks...
Old Nov 4, 2005 | 05:05 AM
tripleGmax's Avatar
first, they will never sit flush. second they will be a biitch to clean. dont go with those, youll save yourself about 300 headaches. get projectors that have a glass housing. they will look better. brad92se and dmad and realgoon9 all have them
Old Nov 4, 2005 | 05:22 AM
ElVito1981's Avatar
Ok, but will the projectors pass inspection? That's the only thing that would stop me from getting them.
Old Nov 4, 2005 | 05:48 AM
Wiking's Avatar
Originally Posted by ElVito1981
what's the difference between projectors and regular lights?
From Hella -pages; Projector-type system:
In this system, the reflector has no regulating geometry, but is a free-form system (FF®) which collects the light generated by the light source near a first focal plane. The light is then projected into a second focal plane in which a shield is located. The contour of the shield is then mapped to the road by a lens.
read hella .pdf:
http://www.hella.com/produktion/Hell...e_GB_TT_18.pdf
BMW replacements:
Old Nov 4, 2005 | 10:35 AM
ElVito1981's Avatar
would the euro E36 projector lights pass state inspection? I'm in VA.
Old Nov 4, 2005 | 01:34 PM
internetautomar's Avatar
mod or sell?
that will depend on the inspector, and how you vote in the next election
Old Nov 4, 2005 | 05:17 PM
ElVito1981's Avatar
so would you say it's more likely that my car will pass inspection if I buy the regular US E36 vs. the Euro projectors?
Old Nov 5, 2005 | 01:19 AM
Wiking's Avatar
....will pass inspection if ...
This issue is taxmans issue. Each lamp lens has to have a sign telling that lots license money from lens producer has passed to gvmt coffers. Different gvmts have different requirements, thus labels differ. Good way to ensure income. Bűreucrazies are at their best following up these nuances, dont expect to bypass them. Maybe using 36U$ as a pass, u will pass...?
Old Nov 5, 2005 | 06:15 PM
mod or sell?
the USDM E36 are at least aimed correctly for US roads
Old Nov 5, 2005 | 07:53 PM
ElVito1981's Avatar
yeah, then just to be safe, i better get the US ones, even though I think the Euro lights are way cooler. Thanks guys
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
