Wiper Piviot Point
Old Nov 2, 2005 | 05:03 PM
Mike S.'s Avatar
Wiper Pivot Point
The pivot point on my drivers side wiper is loose. The arm is tight on the pivot, but the pivot itself can be rocked around. As a result, the wiper arm rubs against the hood when its leaving the lowered position.
Any others with this issue?
Can I just tighten the pivot? or do I need to replace it?
I've checked the FSM.pdf and I can't find it.
Mike S.
EDIT: By pivot, i mean the spindle that the arm attaches too.
Old Nov 2, 2005 | 05:37 PM
Greeny's Avatar
¯\(°_o)/¯
Do you mean this....
I have a good used wiper for sale if you want it...
Old Nov 2, 2005 | 06:30 PM
Mike S.'s Avatar
Sorry...should have been more specific.
I mean the spindle that the wiper arm attaches too.
Mike S.
Old Nov 2, 2005 | 11:49 PM
Wiking's Avatar
FSM is full of holes. Here sits a viperhole...
I suppose its like other nissans: plastic bushing that wears out. Poor de-sign quality ... Wish the three 'spindle' assy attachement nuts are loose? Take the car wide blk panel out... Hidden under small plastic bits are couple of x -screws, couple of plastic lock bits.
Car Needs to be changed or this bearing lubricated - periodically. Buy new poor quality bushing from shop.
Old Nov 3, 2005 | 12:08 AM
silver91's Avatar
I have the same issue with my passenger side wiper
Old Nov 3, 2005 | 06:02 AM
Tarzan's Avatar
Been there done that. I had exact same problem 3 years ago. Had to buy 2 new pivots, 2 new connections and replace them all. Took me 2 hours due to the pivot screws had to be drilled out - PITA to drill with a cordless drill in an apartment building parking lot.
Why that happens? Because the galvanized arm axles finally wear off the coat and rust, rust separates from them and becomes highly abrasive on the nylon pivots. End result pivot has oval tapering inside and the axles start playing.
Old Nov 4, 2005 | 06:42 PM
Mike S.'s Avatar
Hmmm..i need to price this out. Guess I should buy new instead of a junk yard part.
Old Nov 18, 2005 | 07:06 PM
JstAntrRoky's Avatar
Well I know for the passanger side pivot arm at my local dealer it cost me 30.00
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
