having trouble replacing axles
Old Nov 7, 2005 | 04:00 PM
Tonyklem's Avatar
I am having trouble fitting the driver side axle into place. Its the same thing as the one i took out, so i know i have the right one. When i seat it into the transmission and try to get it through the rotor, it stops short and doesnt seat completely against the back of the rotor (or whatever it sits against i dont remember). I tried tightening the nut on the end of the axle to try to pull it through the rotor, but it just pulls the other end out of the tranny. The axle does have some play in it when you pull on both ends to compensate for suspension movement, but it just goes back together. Any suggestions?
Old Nov 7, 2005 | 04:07 PM
Greeny's Avatar
¯\(°_o)/¯
Are the driveshaft splines lined up with the splines in the hub??
You might have a piece trash inside the hub stopping it from seating correctly.
got any pics???
Old Nov 7, 2005 | 04:16 PM
Aaron92SE's Avatar
NWP Engineering.com
You have to jam that new axle in place. It needs to snap into place. Make sure that the end that goes into the tranny has that little metal ring on it. If it doesn't, then it has no way to stay in.
I bet you aren't pushing it into the tranny hard enough. Jam it in place, then pull on it slightly to see if it falls out. If it doesn't, then bolt it all up and you're done.
And like, Mygreenmax said, make sure the splines are lined up. It shouldn't be that hard to line them up. It just falls into place, then after that, jam it in there really hard.
Old Nov 7, 2005 | 04:18 PM
Tonyklem's Avatar
Ya everything was lined up right and no trash. I looked at the axles again and found that the ring on the end that goes into the tranny was smaller on the new one, so i just switched them. Thanks for the input guys
Old Nov 7, 2005 | 04:23 PM
Greeny's Avatar
¯\(°_o)/¯
It should look like this when seated all the way in...
Old Nov 7, 2005 | 05:18 PM
Blackbob's Avatar
Looks like it's pullin a honda on you....Take it out the hub. Then PB blast both the hub splines and the ones on the axle...wipe clean...LIGHTLY WD40 the axle splines and that should do the trick.
~BB~
Old Nov 7, 2005 | 05:28 PM
Tonyklem's Avatar
I got it together, the little ring on the end that goes into the tranny was too small so it just kept popping out. So i put the old one on it and it works now.
Old Nov 7, 2005 | 09:04 PM
Aaron92SE's Avatar
NWP Engineering.com
Word! Good job!
Old Nov 7, 2005 | 10:57 PM
Squeakuhuh's Avatar
How much did you pay for a front axle? My 92 GXE just got into a nasty side-swipe, and I need a new rear axle, along with at lease a rear door and quarter panel. It's a sad day in this man's life.
Old Nov 8, 2005 | 04:44 AM
internetautomar's Avatar
mod or sell?
there is no rear axle on these cars
Old Nov 8, 2005 | 05:42 AM
Hectic's Avatar
wow, i didn't know parts from the titanic were compatible
Old Nov 8, 2005 | 06:59 AM
Greeny's Avatar
¯\(°_o)/¯
Hehe.. ....Them are the hub-n-axle off my parts car....The car spent it's last days in North Carolina...Hence the red clay all over the suspension parts....
Old Nov 8, 2005 | 07:44 AM
Aaron92SE's Avatar
NWP Engineering.com
You must have been in the moutains in NC. I don't think I've seen too much red clay like that anywhere but the moutain region of NC.
Old Nov 8, 2005 | 03:54 PM
Greeny's Avatar
¯\(°_o)/¯
I never have lived there....I went there to pick it up from a org member that gave it to me....
Old Nov 8, 2005 | 04:18 PM
CyMax's Avatar
Come to Apex..... Narsty clay !!!
Old Nov 8, 2005 | 04:35 PM
CyMax's Avatar
Cool, now come and do mine for me!
Old Nov 8, 2005 | 04:41 PM
Greeny's Avatar
¯\(°_o)/¯
You need to lay off the sauce Cy....
Old Nov 8, 2005 | 06:22 PM
Squeakuhuh's Avatar
okay, no rear axle, indepentent sus...i forgot. Any idea on how much it would cost for just the rear passenger side susp. to be replaced? Or should i just look into trying to part it out or selling it for a parts car? ...any takers?
Old Nov 8, 2005 | 06:31 PM
mod or sell?
the rear suspension is comprised of several easily replaceable parts.
Heck on my old max I had 2 bent arms on the rear but it was perfectly aligned and had no problems that ever cropped up. I was surprised when I saw the bent pieces
Old Nov 10, 2005 | 09:37 PM
Squeakuhuh's Avatar
yeah, but if it has been in a major collision, is it plausible to fix it?
Old Nov 10, 2005 | 10:35 PM
Golden Ice's Avatar
yep..I would just about bet that mine was hit harder in 94 or 95 when my aunt was hit in the right rear by a '78 pontiac station wagon traveling 50+ mph..can't tell it ever happend by looking at the suspension..
Old Nov 11, 2005 | 05:28 AM
mod or sell?
you'd be amazed at what you can rebuild to like new specs
Old Nov 11, 2005 | 07:08 AM
Greeny's Avatar
¯\(°_o)/¯
IMO, to rebuild a crushed up rearend of any car you need access to more then just basic handtools and more then basic repairing skills...If you don't have either of the 2,i wouldn't attempt it...
It would be easier to me to just buy another car then to try and fix a crushed rear end...These cars are on every street corner,some of them for sale cheap....
Old Nov 11, 2005 | 11:51 AM
Squeakuhuh's Avatar
How much do you think I could get for a smashed up max?
Old Nov 11, 2005 | 12:05 PM
mod or sell?
the extent of the damage will be what decides whether you can easily fix it or not.
and a smashed up GXE ain't worth much.
I only got offered $450 for my VE5 that is hit in the rear, no frame damage
Old Nov 13, 2005 | 04:57 AM
Hectic's Avatar
what's the color/milage of the car? any pics of the car in it's current state?
thanks man.
Old Nov 13, 2005 | 01:46 PM
Squeakuhuh's Avatar
Well, it's a 92 GXE, Beige/champegne....whatever you want to call it. 178k miles, and it got hit in the rear passenger. It was towed from the scene, I then drove it home(with the suspension in bad shape), but now it's sat there for quite a while...no time. The rear quarter panel needs replaced, along with the tail-light, and rear passenger door. Everything else is in quite wonderful shape, minus normal wear and a dent on the front driver side. Just changed the plugs and oil before it was in this unfortunate state. Let me know if you need more info, Hectic.
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
PH98I30
Aug 20, 2015 04:25 PM
classymax420
Aug 6, 2015 06:35 PM
