power locks
Old Jun 2, 2001 | 09:39 AM
jorgeg73's Avatar
how do I reset the power lock timer?
Old Jun 2, 2001 | 09:53 PM
bigjay's Avatar
wha's the problem you are experienceing?
Old Jun 3, 2001 | 12:53 AM
jorgeg73's Avatar
power locks
Earlier a wrote that I had problems whit my 94 maxima
When I push the lock unlock I can ear the clicking of the relay but the lock do not move non, I put a voltmeter on the lock motor to se the voltage an because is a pulse i can not se the voltage but I also put a 12 volt batterry on the motor an it move so I can say that the motors are working fine, some body wrote me and say it cound be whit the timing , I do not know what that is so if you can help please do.
Thank You
Old Jun 3, 2001 | 07:20 PM
Jaybird180's Avatar
Re: power locks
Thank You
Remove the door lock timer and resolder all the connections. Worked for me. Saved me the cost of a new one. And still working since.
Old Jun 3, 2001 | 10:39 PM
bigjay's Avatar
and also if you have the upgraded alarm system
for the maxima that shut's your sun roof and all windows roll up, and the door's all lock(came with my se 92)there was a problem i had with the grounding of the other doors because the drivers door ran on a diffrent circut and it would just make noise, also the motor for the drivers door lock actuator was getting power and opperateing but the gears inside were shot, so make sure it is fully opperateing not just turning on and off, hope this helps
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
