5speed grinding in second
Old Nov 11, 2005 | 06:18 AM
95turbo gxe's Avatar
Ok I was wondering why my tranny grinds going into second? Whats wrong with it? It been doing this for a while. It grind just about everytime. would this
be an easy cheap fix if I take the tranny back out?
Old Nov 11, 2005 | 07:00 AM
Greeny's Avatar
¯\(°_o)/¯
The problem is most likely the second gear syncro is going,going...gone.
I have heard a few on here say the ve tranny is alittle stronger then the vg tranny..
Might think about upgrading to it since you are turboed..
Old Nov 11, 2005 | 09:21 AM
tripleGmax's Avatar
ha na dont go upgrading the tranny to a VE when youd have to change out axles.
what causes the snycros to go bad? bad shifting? or just time?
Old Nov 11, 2005 | 09:52 AM
Guys I all ready have the ve 5speed vlsd. I did that swap before boost.
Old Nov 11, 2005 | 10:50 AM
mtcookson's Avatar
the problem... borg warner
syncros are probably going out. make sure you aren't using gl-5 gear oil as that definitely won't help. its most likely too late for that though and it might possibly need a new synchro.
i can't remember if they do or not, but www.drivetrain.com might sell them.
Old Nov 11, 2005 | 12:58 PM
Brad92SE's Avatar
Mine also does this occasionally, except it grinds going into 3rd also, and sometimes 4th lightly. It's not so much an audible grind, as it is just feeling the gears through the shifter not meshing right away. My old gear set did this as well. I'm wondering if my MC just needs adjusting, or if its the Redline tranny fluid I have in it (MT-90).
Old Nov 11, 2005 | 01:09 PM
tripleGmax's Avatar
adjust the clutch??
Old Nov 11, 2005 | 01:40 PM
subs1000w's Avatar
the only difference between the VG and VE trans is the vlsd/ring gear. the internals ie gears shafts bearings are all the same even the 2nd gen vg trans has the same stuff but the syncros were upgraded for the 3rd gen
if it only grinds going into 2nd its the syncro if it grinds going into all gears it would be a clutch problem
drivetrain.com does sell the syncro kit for 250 thats all the syncros to get induvidual ones youd have to order from a dealer and there about 60-80 a piece
Old Nov 11, 2005 | 01:45 PM
nismosleeper's Avatar
The syncros are copper IIRC and as they age, they start going out. The weather can also contribute to difficult shifting. I would use redline mtl. It is expensive, but in order to maintain the Borg Warner POS under boost, you need to use good gear oil. It isn't that easy to fix, but the oil could help out the situation.
Old Nov 11, 2005 | 01:53 PM
subs1000w's Avatar
for future reference the syncros are made of brass
Old Nov 11, 2005 | 09:27 PM
Thank you; I was close.
Old Nov 12, 2005 | 01:55 PM
Duckman540i's Avatar
VE Powah!!!
The syncros have a sharp edge at the end of each tooth, they should be more rounded so that there will be much less of a stress point on the tips. Also they crack on there weakspots, Most likely from fast/hard shifts. If they crack on the other side as well, then your going to lock up your tranny. The syncro will jam into the gears. This happened to my uncle on the freeway! Too many people shift hard & fast, Not Good! If you want to shift fast, then you do it lightly & smoothly. Your syncros will appreciate it. Also thats just the correct way to shift. There is a race driving technique stated: "The slower you are.....The faster the car will go"
Old Nov 12, 2005 | 02:10 PM
True that. Kids think that scratching gears makes their cars faster....ain't true.
Old Nov 13, 2005 | 08:36 PM
mtcookson's Avatar
unless you have straight cut gears with dog engagement syncros and a sequential shifter...
if anyone wants a fwd sequential tranny quaife sells them for the low low cost of 15 grand
Old Nov 13, 2005 | 09:05 PM
Shift_my vq's Avatar
another thing I did when I had a problem with my car grinding into third is I replaced a broken motor mount and it completly solved my problem for some reason.
Old Nov 14, 2005 | 04:38 AM
dam I do have some ****ty mounts! maybe ill be that luckey
Old Nov 14, 2005 | 07:25 AM
Dillbag's Avatar
Suprise butsechs!!!
Yeah, it's probly the synchro/blocking ring, the 1-2 shift is the hardest as far as torque on the drivetrain, and the big difference between engine and wheel speed.
there's a couple used VE tranny's in the classifieds section, maybe pick one up for cheap, slap it in and rebuild the one you have now?
Old Nov 14, 2005 | 07:31 AM
Dillbag's Avatar
Suprise butsechs!!!
or if you can afford the downtime, just pull out the one you have and rebuild it. the factory manual has all the instructions. that's what i used when i rebuilt mine with a buddy a few years back. I think you may need a coulpe special tools like a press.
Old Nov 15, 2005 | 09:40 PM
ebaker's Avatar
Make sure the clutch is fully releasing. Changing the fluid to make sure it has GL4 transaxle fluid and not GL5 gear oil might help. Redline manual transmission light fluid is excellent but expensive. The GL5 oils have too much anti friction additives that make the syncros slip when they should grab.
Old Nov 16, 2005 | 09:12 AM
Alex_V
My 5 speed doesnt go into first unless im under 15 or 10mph. about 3 times at a stop light its not gone into fist w/o a heavy push, or pushing the clutch all the way down. I dont know what the cause is though. I need to check the oil level. Ill search through old threads or some one can post it. (i really need to donate...) Im thinking one of the imput bearings are gone. The tranny does have 217K (im assuming any way, the parts car it came out of had that much miles)
~Alex
Old Nov 16, 2005 | 11:56 AM
mtcookson's Avatar
the majority of manual trannies won't go into first until you're under 10-15 mph. if you want it to go in you can double clutch and it will go in smooth as silk.
Old Nov 16, 2005 | 01:35 PM
tripleGmax's Avatar
Alex.....Granny shiftin' not double clutchin' like you should
Old Nov 16, 2005 | 01:55 PM
Alex_V
Oh ok My s-10 would go into first real easy, it might just be the way the max is I guess. At any rate im more worried about getting it to run smoother....
tripleGmax, meh thats for ricers. Ill power shift all i want
~Alex
Old Nov 16, 2005 | 06:47 PM
mtcookson's Avatar
but you'll blow your intake manifold and your floorboards will fall out!! it'll still run just fine, but it would be nuisance.
Old Nov 18, 2005 | 12:41 PM
for some reason it doesnt grind first thing in the morning! until it warms up. maybe after three shifts into second it wont,and then it will start
carlosvq30
Sep 26, 2015 09:44 AM
MaxRPM6
Sep 11, 2015 06:56 PM
I<3 A32's
Sep 10, 2015 11:07 AM
Lowered_a33
Sep 1, 2015 07:49 PM
