Another wierd VTC problem
Old Nov 11, 2005 | 10:01 PM
blackandwhite's Avatar
To them I'm like an idol
Okay...recently, my vtc soleniod harness was damaged by an oil leak. At first, I thought it was coming from somewhere else under the hood, but after fixing it in the crude fashion shown, I noticed that the leak is coming from the soleniod itself....has anyone ever seen this?
Old Nov 12, 2005 | 02:12 PM
subs1000w's Avatar
is it leaking from where the soliniod screws into the head if so there is an oring that probobly need to be replaced
Old Nov 15, 2005 | 12:02 AM
It appears to be leaking at the harness connector
Old Nov 15, 2005 | 02:14 AM
Wiking's Avatar
It doesnt show up in the pic. I guess u have soldered wires in pins? U mean it leaks through the valve, at these conn pins? (If so, clean it, maybe add some real tough oil resistant sealant into the 'bottom' of the connector)
Btw. All non soldered crimped connectors will become a trouble spot.
Old Nov 15, 2005 | 02:38 AM
Greeny's Avatar
¯\(°_o)/¯
Someone has a used one f/s in the classifieds......
Old Nov 15, 2005 | 08:13 AM
Basically, The leak corroded the original connector, when I tried to clean the connector, it just cracked and broke, so I soldered wires to the pins and wrapped them in electrical tape to insulate, but it leaked again, and un-did the tape.
It is leaking INSIDE the connector
Old Nov 15, 2005 | 08:23 AM
Jeff92se's Avatar
I'm needing a caw
You need another solenoid? I know I have a few spares around.
Old Nov 15, 2005 | 08:54 AM
Wiking's Avatar
...It is leaking INSIDE the connector
U might get by for a while by heating the plastics (after cleaning all grease out). As plastics is soft around the pins, push down with a screwdriver. Dont heat whole assy, try to keep heat only around pins. Also u may heat the plastics surrounding pins (connector) and get it crimped around the clean pins & your soldered wire (with pliers) when plastics materiel has been heated /softened.
Do this after u know u can get better (if this is u first plastic repair tst, failure risk is relatively high). Anyways, the first option is buying new one, so 'nothing' is lost in trying to repair doomed part.
I am used to solder plastics via heating, and I know that if circumstances are right, such tingie can be made as good as new. BUT. If u think that result is shaky, dont drive...
To satisfy jeff, I say: dont d as I say, but as he says.
Old Nov 15, 2005 | 09:37 AM
Mizeree_X's Avatar
Getting back to his roots
I had the same problem on my white 92SE. I pulled the solenoid harnesses off and they were coated with oil. I just replaced them with new ones....but if you can get used ones cheap enough, go for it.
Old Nov 15, 2005 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
I would say if the connector is potted, you stand a much greater chance at ruining the connector vs fixing it.
Well considering the solenoid uses oil pressure to work and engine oil tends to get a bit hot, the "nothing is lost" is relative. I like both of my eyes.
I really doubt a solder would do anything but heat one little side of the unit.
But how about either stopping with the snide remarks or go ahead and address the the multiple questions Matt has given you to keep you busy. It's in the disc brake conversion thread. Or you can elect to take an unplanned vacation if you like. It's up to you
Old Nov 15, 2005 | 11:55 AM
Apparently...
Matt is coming over tonight, I'll have him look at it and see what he thinks
Old Nov 16, 2005 | 12:21 AM
Wiking's Avatar
....It's up to you
On simple discs, all my info has been already given. As said, only tsts, not txts, will prove if smbdy wants proof. Provide.
From here you may cut me and my facts off any time. Show u iq.
Old Nov 16, 2005 | 06:56 AM
Jeff92se's Avatar
I'm needing a caw
So awnser Matt's questions. 1 more comment about it outside of that thead = ban
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
