Bleeding Brakes?
Old Nov 13, 2005 | 07:15 AM
LegitMafiaBoss's Avatar
Bleeding Brakes?
What is the best way to bleed all four lines to get any air out of the system?
Old Nov 13, 2005 | 08:18 AM
doggunracing's Avatar
You really need another person to help unless you pick up some 'SpeedBleeder' attachments. Start with the farthest caliper down the line, (sorry, just got the car and haven't looked yet) usually the driver's rear. Open the bleeder (with a tube on it into a container) and pump the brake, fill the reservoir, repeat until clear. Don't let the reservoir get too low. Make sure the helper closes the screw while you're pumping. Repeat on pass. rear, pass. front, driver's front.
Old Nov 13, 2005 | 10:06 AM
staticlag's Avatar
Go for the speedbleeders, I have them on my other car and they work great!
Start with the Master Cylinder, then right rear, then left rear, then right front, then the drivers side, then Master Cylinder again.
Old Nov 13, 2005 | 10:48 AM
bvtran's Avatar
94c Big Max
what about cars with abs, the manual said unplug abs before continue, does anyone have pics of where that is located? Someone mnetioned it was nearby the radiator but I couldnt find it.
Old Nov 13, 2005 | 11:06 AM
Greeny's Avatar
¯\(°_o)/¯
Old Nov 14, 2005 | 05:59 PM
bvtran's Avatar
94c Big Max
thanks. just curious for abs equiped max, do I need to unplug the negative battery terminal while bleeding the 4 wheels?
Old Nov 14, 2005 | 06:10 PM
Greeny's Avatar
¯\(°_o)/¯
Not necessary........
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
