my max is working on 5 cyl
Old Nov 15, 2005 | 11:42 AM
red-line-racer's Avatar
i bought a 92 se (ve motor). today i started the car and right away the motor stumbles and squicked right away but it drives well i disconnected each plug to see what cyl was it and i found out is was the 3 cyl that was not working right my question is that could it be the coil pack??? and can you do damage to the cyl if you drive it like that??? thanks 4 the advice
Old Nov 15, 2005 | 01:54 PM
Greeny's Avatar
¯\(°_o)/¯
Could be coil pack..Switch it out with one of the other coil packs to see if the problem transfers to the other cylinder...If the same cylinder is still misfiring then you probably need to replace the injector on that cylinder....
Old Nov 15, 2005 | 03:37 PM
internetautomar's Avatar
mod or sell?
I replaced 7 injectors before the city got my VE, coils were still good. I actually have them in a box in my basement.
it's likely the injector though.
Don't forget to pull the plug to make sure that it's good
oh yeah, I sell injectors, plugs, coil etc...
Old Nov 15, 2005 | 07:07 PM
Slamnasty's Avatar
#3 is under the intake manifold isn't it?
Old Nov 15, 2005 | 07:30 PM
i switched the coil and the spark plug and i still get the same thing i will check out the injector tomorrow
Old Nov 15, 2005 | 07:39 PM
Wolf-Strong's Avatar
I feel your pain...
When I got my 1990 Max for my 18th bday my dad had to take it to the shop to get most of the fuel injectors replaced. I can't complain much because it does run fine, but skips a lot when idling. Stupid injectors cost like $200-400 a piece (I forgot off hand).
I did get my injectors cleaned out recently though and it helped a little so that might be a worthy choice of action.
Old Nov 16, 2005 | 05:30 AM
mod or sell?
injectors run about $100 ea brand new, whatever you do don't get rebuilts, they don't last.
I sell injectors
Old Nov 16, 2005 | 07:15 AM
maximagxe90's Avatar
listen to internetautomar,
he know his stuff,
i had the same experience before,
i had a shop put in a remanufacture injector, and that injector last only for a month, brought the car into another shop replaced with a brand new one,
the car runs alot better then before,
Old Nov 16, 2005 | 12:42 PM
i bought Bosch brand injectors the place i bought them from doesnt say if it new or rebuilt
Old Nov 16, 2005 | 02:13 PM
Alex_V
the price you paid would be a indicator. Over $90 or so would probably be new, or they are just ripping you off. I'd definitly find out...
~Alex
Old Nov 16, 2005 | 04:43 PM
mod or sell?
Bosch should be new, but you didn't buy them from me
Old Nov 17, 2005 | 09:12 AM
ha well it was too late i had already had ordered them when you posted that u sell them
Old Nov 17, 2005 | 04:28 PM
mod or sell?
I sell just about anything for cars that I can lay my hands on
Old Nov 17, 2005 | 04:30 PM
AGELG's Avatar
fan
hey i need the fan asembly for my 91max
Old Nov 17, 2005 | 04:59 PM
mod or sell?
Ok, so send me money
www.internetautomart.com is my site
Old Nov 17, 2005 | 07:34 PM
Ford5.0forlife's Avatar
hmm.. i got a #4 skipping injector same as wolf-strong though its only at idle has been tested to be bad, and skips a bit under heavy load motoring.. what should i do? buy 1 brand new, or 6 (i hear they go 1 after the other), i take it remanufactured from direct auto is out of the question... and no point in getting used injectors off junkyard....
whats the best bet.. even though it doesnt feel like its runs bad it could still probably hurt performance unoticably right?
Old Nov 17, 2005 | 07:44 PM
mod or sell?
actually you'd have better luck with JY injectors than rebuilts.
Old Nov 17, 2005 | 07:51 PM
ok, well in that case ill take my chances w/ 1 brand new injector..
p.s. youve got mail
Old Nov 18, 2005 | 06:51 AM
mod or sell?
got it, you should have it on monday. I also tossed in the o'rings which aren't included normally.
Matt93SE
May 24, 2019 02:58 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Supragte
Aug 12, 2015 10:00 PM
jholley
Aug 11, 2015 09:38 AM
kenc15
Aug 5, 2015 08:29 AM
