hood adjustment
Old Nov 20, 2005 | 03:19 PM
95turbo gxe's Avatar
hood adjustment
is their any way to adjust the hood to keep it from bouning up and down when driving down the road. Like maybe tighten the hood latch where their is not as much play in it.
Old Nov 20, 2005 | 03:32 PM
Greeny's Avatar
¯\(°_o)/¯
The rubber hood rests can be adjusted up to stop the hood from bouncing...Be careful when you twist them because they may break..[old rubber]
Old Nov 20, 2005 | 03:36 PM
Alex_V
use liquid wrench on it before you adj it, it puts some oil in the rubber an it stays in it for a while. I also use it on hoses im removing. helps keep them from cracking so much
~Alex
Old Nov 20, 2005 | 04:42 PM
internetautomar's Avatar
mod or sell?
aren't there also a couple on the hood itself?
or am I thinking of another car I had
Old Nov 20, 2005 | 04:50 PM
Greeny's Avatar
¯\(°_o)/¯
I don't see any..
Old Nov 20, 2005 | 05:07 PM
yeah those things are already gone off my car! (One is broke and one is missing.) Is their anything on the latch it self I can adjust?
Old Nov 20, 2005 | 05:12 PM
Greeny's Avatar
¯\(°_o)/¯
That is why your hood is bouncing.....Adjusting latches is not going to fix it....The dealer sells them pretty cheap[$3-$5 a piece]
Old Nov 20, 2005 | 05:22 PM
ok kool 78910
Old Nov 20, 2005 | 05:45 PM
Michael's Avatar
Back in a 3rd Gen.
Originally Posted by MyGreenMax94
I don't see any..
look again then...
The ones on the hood are the ones that put the most pressure on the hood. They help make the hood pop up and keep it from bouncing.
Here are pictures of the bumpstops on the hood. I recomend replacing them and the ones on the radiator support...they arent expensive.
Old Nov 20, 2005 | 05:54 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by awsm66
look again then...
Thanks for the owning...
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
leatherneck
Sep 30, 2015 09:16 PM
