To anyone who has replaced their IACV on a VE Motor
Old Nov 22, 2005 | 05:23 PM
MaXtUneD's Avatar
When you guys replaced your old IACV for a new one, Are their any gaskets that I need to buy to replace the old one(s)...Also, would I have to take the throttle body off to get to the IACV?
Old Nov 22, 2005 | 05:29 PM
Greeny's Avatar
¯\(°_o)/¯
Yes there is a gasket....No you dont have to take the tb off to get to it....When i took mine off to clean it,my gasket didn't break or tear..So i just reused it...If your going to replace it with a new one then i would buy the gasket...
Old Nov 22, 2005 | 07:55 PM
Harvs94max's Avatar
i would buy a gasket regardless or get some liquid gasket any small leak will fawk up ur idle
Old Nov 23, 2005 | 07:01 AM
Cliff Clavin's Avatar
Way out West
The gasket is cheap, just get it from a dealer. I suggest actually replacing the both the TB and IACV gasket at the same time. It's easier to access the IACV with the TB off and you can clean both thoroughly. You don't have to take the TB off, but while you are in there, you might as well clean up everything you can and not worry about it for a while.
One word of caution: because our cars are pretty old, they might not have the gaskets in stock, especially the IACV. I would make sure you have the gaskets IN YOUR HAND before actually disassembling your car.
Old Nov 23, 2005 | 09:10 AM
MrGone's Avatar
buy a new one
chances are it will tear and could cause you a headache. I've had a few that haven't but most have, regardless I still use sealer on them. IACV = not fun to have a vacuum leak with (even moreso with a boosted car)
Old Nov 23, 2005 | 10:51 AM
jwmaxse's Avatar
If the gasket is crap and you can't find one at a dealer you can always make a gasket yourself. They sell gasket material at AutoZone and you can just trace the old gasket and cut the new one out with an exacto knife.
Old Nov 23, 2005 | 01:05 PM
MaXtUneD's Avatar
Hey guys...What is the OEM number for our IACV for Manual transmission DOHC Motor?
Old Nov 23, 2005 | 03:40 PM
internetautomar's Avatar
mod or sell?
why do you need the OEM #?
Old Nov 23, 2005 | 06:30 PM
Way out West
you definitely don't want to buy a new one for a dealer. You could probably get a JWT ECU for that much.
Old Nov 23, 2005 | 06:51 PM
mod or sell?
But a JWT ECU won't fix his problem.
BTW I do have IACVs for sale brand new
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
homeyclaus
Sep 3, 2015 06:15 PM
