A/f ratio gauge
Here are some general instructions for other cars...I am not sure if these will work for the maxima...
http://www.egauges.com/vdo_mult.asp?...0my%20vehicle?
http://rdmelton.autoeducation.com/cars/stealth/af.html
1. open disco
2. plug into power
3. ???
4. Profit
really, don't even bother it's totally worthless unless it's hooked to a wideband o2
2. plug into power
3. ???
4. Profit
I just searched and jeff said the same thing...
http://forums.maxima.org/showthread....el+ratio+gauge
but otherwise
edit: and it would be even more worthless to hook it up to a wideband.
1. open disco
2. plug into power
3. ???
4. Profit
2. plug into power
3. ???
4. Profit
Originally Posted by Sgibb
Why would it be worthless?
Because, all you have is a gauge. The stock o2 sensor can only pick out a/f ratios near 14.7:1, which is nearly useless. To make the gauge accurate you need a wideband o2 gauge. Then that gives you an accurate a/f reading. But what can you do with it? nothing because you dont have an engine management system that lets you change your a/f ratio. Unless you buy a S-AFC II. But all that would run a couple hundred dollers. It'd get you more power and possibly better gas milage though.
~Alex
~Alex
the A/F gauge is handy for determining the load on an engine and could help you adjust your driving style. It is useful to a degree, just not for specifically determining the engines mixture.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
