High Idle/Surging
Old Nov 30, 2005 | 09:58 PM
Tom's Avatar
Tom
High Idle/Surging
I noticed lately that after I drive to work (a good 12 miles away) and put my car into PARK, the idle surges to about 1100 RPM (sometimes 1400-1500 RPM), then it comes down. Also, I noticed it idles about 900 RPM now also.
It drives fine otherwise. Anything I should check?
Old Nov 30, 2005 | 10:15 PM
Scope's Avatar
Im izz sexay
What type of gas did you use. My brothers integra does this when he uses cheap 87 octane.
Old Nov 30, 2005 | 11:16 PM
95turbo gxe's Avatar
check the idel air control vaule or maybe look for A vacum leak.
Old Dec 1, 2005 | 04:43 AM
Greeny's Avatar
¯\(°_o)/¯
Check ALL the vacuum hoses for broken and/or cracked hoses...If all ok the n look into the iacv for a good cleaning or replacement...
Old Dec 1, 2005 | 11:46 AM
Alex_V
Try new gas first. Some times my mom would get cheap gas in her max and it would run like complete garbage. Just put some nice 89 or better in it. The max will thank you.
~Alex
Old Dec 1, 2005 | 05:28 PM
maxitech's Avatar
Where is the iacv located?
NEVER by Speedway gas. It's CRAP!! Just My 2 cents.
Old Dec 1, 2005 | 05:56 PM
Greeny's Avatar
¯\(°_o)/¯
Old Dec 1, 2005 | 06:47 PM
Dillbag's Avatar
Suprise butsechs!!!
I'm leaning toward cracked-out IACV, but yeah, try different gas and checking for vacum leaks first.
Old Dec 1, 2005 | 08:57 PM
Tom's Avatar
Tom
I always buy gas from the same Chevron gas station. I filled it with nothing but 87 octane, except for a few times.
I'll check the IACV and vacuum hoes. Thanks.
Old Dec 2, 2005 | 06:13 AM
danatimm's Avatar
I have a 92 to max and lately it has a random problem. it idles very poorly (0-500) and bounces around. When this happens i get poor gas mileage(approx. 50 miles 1/2 tank, and i nearly get smoked out of my car it stinks (gas) :attention . i constantly need to stay on the accelerater to keep it running. it has a hard time shifting when this happens also. then just as random as it started it stops. it lasts for two days somtimes two minutes. ive replaced the maf and that didnt do the trick. any suggestions would be fantastic thanks
Old Dec 2, 2005 | 06:49 AM
Greeny's Avatar
¯\(°_o)/¯
Can we say....Bad fuel injectors....
Old Dec 2, 2005 | 10:22 AM
danatimm's Avatar
if it were the injectors wouldnt it happen all the time?
Old Dec 2, 2005 | 11:06 AM
Scope's Avatar
Im izz sexay
Not Necessary. When things on a car begin to go they work then dont then work again until it dies. When was the last time you changed the plugs and wires with some good ones, not the cheap $8 wire set but something in the premium range?
Old Dec 2, 2005 | 12:11 PM
danatimm's Avatar
i just bought the car and to honest i dont even know if its the gxe se and
so on there are no badges on it
Old Dec 2, 2005 | 12:37 PM
Greeny's Avatar
¯\(°_o)/¯
Does the motor look like this???
Old Dec 2, 2005 | 01:18 PM
danatimm's Avatar
no it doesn look like the one pictured
Old Dec 2, 2005 | 06:08 PM
Maxima Man's Avatar
Then its got a vg motor if 89 91 the se all gxes have vg motor
Old Dec 2, 2005 | 10:18 PM
Wolf-Strong's Avatar
First off, I'm sorry for doing a little hijack here, but now I am really curious...this would be the VG right?
I know I got an SE...but I really know very little...knowing which motor I have would really help so thanks in advance!
Old Dec 2, 2005 | 10:36 PM
Originally Posted by MyGreenMax94
WAIT is their something wrong with my car my engine bay does not look like that....
Dam i need to update my pics of the new piping to the intercooler
Old Dec 3, 2005 | 08:24 AM
Hectic's Avatar
Originally Posted by VD Providah
Not Necessary
don't you mean "not necessarily"? come on man, didn't you go to pimp college?
Old Dec 3, 2005 | 01:01 PM
Cliff Clavin's Avatar
Way out West
You guys with idle problems should start by checking your ECU for problem codes. If you aren't sure how to do this, spend a little time looking through the stickies -- the information is in there if you do a little digging.
IACV and hoses are good places to start. Mine was acting batty and it was my coolant temp sensor. The IACV also added to the problem.
Old Dec 4, 2005 | 09:13 AM
Scope's Avatar
Im izz sexay
You know when we're giving the smack down grammar is the last thing on our mind.
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
