power steering noise....
Old Dec 3, 2005 | 10:05 AM
slickblack94's Avatar
Hi, I recently changed the high pressure hose for the power steering system
and tried to get excess air out by turning wheel from left to right stoper to stopper. It's been about two months now and i still get a whine from the pump. Im wondering if there is a way to get anymore air out or did i put hose on wrong? thanks
Old Dec 3, 2005 | 10:50 AM
Greeny's Avatar
¯\(°_o)/¯
Bleeding procedure per fsm:
1. Raise front of vehicle until wheels are clear of the ground
2. add fluid into tank to specified level, turn steering wheel quickly from left to right,lightly touching the steering stoppers..repeat procedure until fluid level stops going down..
3. Start engine, then repeat step 2 with the engine running...
Old Dec 3, 2005 | 12:01 PM
bhunter's Avatar
That whine might not go away. My green one leaked and I finally changed the hose but I think the low fluid level damaged the pump. It still works fine and it has been about 9 months. My daughter plays the stereo loud and I am the only one who notices
Old Dec 9, 2005 | 03:25 AM
DaWifey's90's Avatar
what can my max do for me
just to make sure, after you bleed the system are you topping off the fluid?
seems like an obvious thing to do but is often overlooked
lowpost99
Oct 26, 2025 06:53 PM
Fbana41
Aug 29, 2016 12:18 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
