Car sits crooked
Old Dec 16, 2005 | 08:41 AM
bhunter's Avatar
Car sits crooked
My youngest came home from college (93 Black Emerald). I noticed as I left this morning the front end sits crooked. The driver's side I could set my whole hand between the tire and wheel well. On the passenger side I could only tightly put four fingers, so there is about and inch difference. Is this struts?
Old Dec 16, 2005 | 08:43 AM
Greeny's Avatar
¯\(°_o)/¯
Probably a blown strut...I would check the spring too...
Old Dec 16, 2005 | 09:58 AM
tripleGmax's Avatar
i would think struts too. but def check the spring.
Old Dec 16, 2005 | 10:00 AM
Jeff92se's Avatar
I'm needing a caw
Since the original struts aren't gas type, I don't think it's a strut. More likely a spring is losing it's strength.
Old Dec 16, 2005 | 10:38 AM
bhunter's Avatar
How exactly would I check the spring? Remove it see how tall it stands? Remove both to compare?
Old Dec 16, 2005 | 10:42 AM
Jeff92se's Avatar
I'm needing a caw
Probably have to take both out and compare. I guess you could bounce both sides to see if the slumped side has a blown shock
Old Dec 16, 2005 | 06:28 PM
5 ltr. beater's Avatar
hey, now that u mentioned it, my car sits crooked too! My car is lowered on Eibach's with Monroe sensatrac struts all the way around. I hate making left hand turns going up driveways because the front passenger tire always rubs like a mother. and if you look at the front of the car from far way, that side sits a little lower!
I doubt it's the struts going out. What else could it be? Or is it one of the 3rd Gen mysteries?
Old Dec 17, 2005 | 03:32 PM
internetautomar's Avatar
mod or sell?
I think it's the user, because he cheaped out and bought struts that aren't designed for lowering
Old Dec 17, 2005 | 08:18 PM
VEvolution's Avatar
I miss my VE
You could do a shock bounce test to see if the shock has blown. Firmly bounce the passenger side corner a few times and then let go. Normally a good shock should stop bouncing after 1 or 2 rebounds. 3 or more means the shock is done for. Compare with the drivers side. If both respond the same, you can likely disregard the shocks at fault.
Old Jan 3, 2006 | 05:24 PM
sp3dymax's Avatar
I have the same problem as well... car sits lower on the left side. The whole left side is lower compared to the right. And the car has the same lowering springs all around.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Samedi
Aug 12, 2015 01:54 AM
Flores94
Aug 11, 2015 12:53 PM
acw
Aug 7, 2015 04:20 PM
