Stock Fog Light Question
Old Dec 22, 2005 | 06:41 PM
SoMarvelus's Avatar
When i bought my max the guy i got it from said that he had fog lights cuz its an SE but he said they broke so i dont have fogs anymore at the time i liked the no fog look but im starting to like the fog light look. so my Q is what all do i need to get the stock fogs back to install and all...i also head that i can get the same shape and look from like Autozone fogs and all, when i opened the box all i saw was the housing. what would i need to get the look cuz i only like the shape
Old Dec 22, 2005 | 07:32 PM
tripleGmax's Avatar
courtesynissan has oem ones for 30 a piece.
Old Dec 22, 2005 | 08:45 PM
Cliff Clavin's Avatar
Way out West
I think the courtesy part is only for the glass.
You should check to see if the stock wiring is still OK.
If it is, you probably just need bulbs or glass. If your housings are good, it's probably best to buy the glass. Even if the stock fogs are shot, you can still use the wiring and mount a set of aftermarket fogs to the stock brackets, that way you can use the switch and won't have to wire anything else.
If no juice is making it to the wires up front, you need to track it down and figure out where the problem is. That might be a bish.
Old Dec 23, 2005 | 01:51 AM
DaWifey's90's Avatar
what can my max do for me
if u're wiring is good and the housings are busted, u can also try http://www.car-part.com/
but do a national search (i.e. don't limit the search to your locale). more times than not u can find parts that are cheaper (even with the shipping costs) from faraway shops.
good site to bookmark
Old Dec 23, 2005 | 06:41 AM
bhunter's Avatar
Mine are stock shape but smaller. Got them at Advance, cheap. Sort of a pain to install as I had to drill new holes but it worked out fine.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
