4th Gen Seats?
Old Dec 29, 2005 | 12:13 PM
blackandwhite's Avatar
To them I'm like an idol
4th Gen Seats?
Will they bolt-on? If not, Can they be modded to fit?
Old Dec 29, 2005 | 12:24 PM
goon9's Avatar
No, anything can be modded to fit.
Old Dec 29, 2005 | 02:02 PM
jwmaxse's Avatar
I've ridden in my 4th gen seats for more than 25,000 miles and I'd have to say that they're not worth putting in any other car. The third gen seats are more comfortable than the fourth gen. Why do you want to put them in your third gen?
Old Dec 29, 2005 | 02:08 PM
tripleGmax's Avatar
probably easier to find decent leather from a 4th gen....
Old Dec 29, 2005 | 02:27 PM
exactly
Old Dec 29, 2005 | 02:33 PM
jwmaxse's Avatar
Here's what I would do if I were you:
http://forums.maxima.org/showthread.php?t=447497
Since you're probably going to have to do modification to put 4th gen seats in you might as well just put in the Z seats. You would still need to find the rear 3rd gen seats somewhere though...
Old Dec 29, 2005 | 03:35 PM
internetautomar's Avatar
mod or sell?
actually a little searching goes a long way.
http://forums.maxima.org/showthread....ight=4th+seats
you are a donating member
Old Dec 29, 2005 | 04:40 PM
jwmaxse's Avatar
I'd get a 4th gen rear seat then and get something sporty for the front, like G35 or Z seats, that's my final answer
Old Dec 30, 2005 | 06:23 AM
I saw this when I searched, but my problem is that the seat I need to replace MOST is the rear backrest part. I have already replaced the driver seat (had it re-covered), and the passender is OK for now.
Old Dec 30, 2005 | 06:33 AM
I did search, I found examples of people saying that it was easy, just a bolt on, like you said, and other saying that it would take a bunch of stripping and welding, which I am not interested in doing.
Old Jan 1, 2006 | 07:07 AM
shvelle's Avatar
I have 4th gen seats in my 3rd gen and no they will not simply bolt in. You do need to make some pretty extensive mods to the seat tracks or the mounting points on the floor. Since you aren't interested in that, then I guess you'll need to find other seats or simply recover your existing ones.
And yes, 4th gen seats aren't as comfortable as 3rd gen seats, but they're not as bad as some seem to make them out to be.
Old Jan 1, 2006 | 04:53 PM
Maxima-4DSC's Avatar
YoU CaNt SeE mE
I used to own a 3rd gen for a few years. during that time i put in 4th gen seats. maximaboi has the car now. One side of the seats will fit the other you will have to cut the old seat mount out (plasma cutter works nice or sawzall) and weld a new mount in place. you can go to home depot and get some metal to fab a mount its not hard. use grade 8 bolts to put the seat in place after you level it and get it strait. the 4th gen seats arent as comfoortable as the 3rd gen ones like everyone has been saying. i have a 4th gen now a 99se and the seats just dont get more comfy that the 3rd gen....also the rear seats will require fab work but can be done cheeply. the bottom part will fit with some "convincing" the back part does not line up you can use heavy grade tie wire to strap that sucker down. or you can do it the right way and fab brackets with some hole punched steel.
Old Jan 3, 2006 | 06:15 AM
Okay, what if I only need to replace the backrest of the rear? I don't need to replace the front
MAXSE5SPD
Sep 17, 2022 04:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
Violator
Sep 9, 2015 10:14 AM
GregL65
Sep 5, 2015 09:37 PM
Lowered_a33
Sep 1, 2015 07:49 PM
